We have been using 1.5 in production with MX 6.1 for the last
6 months and we will soon upgrade to MX 7.0.1.
We have encountered problems with calling webservices (when
CF tries to generate code for the webservice it is using a version
of axis that has a package name containing ".enum." which is not
allowed in 1.5), but I think that this problem will go away when we
upgrade to MX 7.0.1 since it uses a newer version of axis with the
particular packages renamed to be 1.5 compatible. We can currently
create webservices for others to call, we just can't initiate
webservice requests from CF.
In WEB-INF/cfusion/lib there is a 1.4 version of tools.jar
which we had to replace with the 1.5 version and in this same
directory we had to remove jikesw.exe. These two changes were
necessary in order for calling our webservices to work (the java
code generated for the webservices gets compiled using either
jikes, if present -- which doesn't work with 1.5, or the java
compiler in tools.jar (in which case the tools.jar needs to be in
synch with your jdk version).
Otherwise we haven't had any issues -- of course I strongly
recommend running with 1.5 in your development environment for a
decent amout of time before taking it into production and in
particular make sure your webservices (if you're using any) still
work. You also could run into problems (ClassCastException) with
date comparisons due to changes in the Timestamp class in 1.5 if
you try to compare Timestamp objects to Date objects in CF (we
didn't encounter this particular problem in any of our code).
Ryan
