2
How do I resize a graph?
Jun 29, 2009 Jun 29, 2009
Hello,
how do I resize a graph? From what I can see, I can only set its size when I create it?
I guess I could Transform > Scale an existing graph - but I'd rather set a fixed width and height so I can keep the proportions right for when I import the graph into InDesign.
107.7K
Adobe
The final size of your graph depends amongst other things on the size of the type and the number of digits in the XY values. So rescaling with either the Scale ot Transform tools is almost always necessary. I suggest snapping ruler guides to a rectangle which is in the correct size may be a good idea. Then you can always snap your graph to fit to the guides. Be aware that simple scaling will result in the type becoming distorted. You can select the type by double (or treble)-clicking on one of the digits with the Direct Selection (white arrow) tool. That way you select the whole group to adjust the size of the type.
Select the graph click on the graph tool in the tool bar there is an x axis settings for the drop down gives you some control.
So does the columns width settings.
May 28, 2015 May 28, 2015
You can also follow this:
Select the graph with the selection tool (v) -> Right click -> Scale-> uniform selection, input as 200% to double its size or 120% to increase the size by 20%. Click OK.
Done!
Dec 05, 2015 Dec 05, 2015
This worked perfectly. Better than all the other options.
Thank you so much ankitas!
Apr 12, 2016 Apr 12, 2016
I found that ungrouping the graph and then resizing as you would with a normal shape also works, but this makes it so you're no longer able to edit the data.
Oct 20, 2016 Oct 20, 2016
If the little spread sheet widget is running then it doesn't seem to work. Just closing that window will allow you to Ungroup the object and then you can resize it.
Mar 23, 2017 Mar 23, 2017
SCALE TOOL
Contributor ,
Jun 12, 2017 Jun 12, 2017
why would anyway want to resize a graph after it's created?
*SARCASM*
Apparently the graph feature hasn't been updated in 20 years.
makes you wonder what they're doing all day.
What I do:
Set artboard to the size I want to drop into indesign as.
Create a graph
Use scale tool to resize graph to size
Leave the Y axis editable. (when you scale the graph it will scale the text too, I keep a copy of the axis text on the side, so after I scale, just select all the scaled text and eye drop the sample text.)
Labels I do as editable text.
Contributor ,
Jul 28, 2023 Jul 28, 2023
Make that 26 years.
The graph tool still sucks.
Sep 21, 2023 Sep 21, 2023
Still waiting, slowed me down a ton today... Such a basic feature that I didn't realise wasn't there until I tried it today.
Adobe don't care about core product anymore, jump on the AI train, because that's the only place they want to go.
[abuse removed by moderator]
Sep 22, 2023 Sep 22, 2023
The answer has been given in 2009 already: use the scale tool.
Jul 25, 2019 Jul 25, 2019
Group with another shape object (anything). Then use the Scale function from the dropdown menu.
Dragging from the transform corners won't work.
