Hi i am using the main.cfc in the examples using the onIncomingMessage event
i am gettnig back a variable
<cfset message="#data.message#">
<!--- where did it come from? --->
<cfset orig="#CFEvent.originatorID#">
<cfset retValue = structNew()>
<cfset retValue.command = "submit">
<cfset retValue.sourceAddress = arguments.CFEVENT.gatewayid>
<cfset retValue.destAddress = arguments.CFEVENT.originatorid>
<cfset retValue.shortMessage = "echo: " & message>
retValue.shortMessage contains all the data and is then written to a text file like this
"Information","Thread-15","06/30/09","21:07:17","IM_MENU","echo: id:869990453 sub:001 dlvrd:001 submit date:0906301507 done date:0906301507 stat:DELIVRD err:000 text:"
what i need is to set 2 variables
1. MessageId = this is the "id" in the echo
2. MessageStatus = this is the "stat"
i am not sure how to get to this info?
could you please paste ur main.cfc
main.cfc below, instead of writing to a txt file i need to create 2 variables to insert into my database
<cffunction name="onIncomingMessage" output="no">
<cfargument name="CFEvent" type="struct" required="yes">
<!--- Get the message --->
<cfset data=cfevent.DATA>
<cfset retValue.shortMessage = "echo: " & messageId>
<cflog file="smsTest" text="#retValue.shortMessage#">
</cffunction>
try this
<cfset temp= listgetat(retValue.shortMessage,6)>
<cfset temparray= listtoarray(temp," ")>
<cfset MessageId = listgetat(temparray[2],2,":")>
<cfset MessageStatus = listgetat(temparray[9],2,":")>
Hi i have tried the below, which did not work, i am not sure how i can debug this to find what the error is, as its a event?
<cfcomponent>
<cflog file="smsTestCraig2" text="#MessageStatus#">
</cffunction>
Use cflog to save information about the request to a log file.
Here's the same statement as above but this time correctly escaped in code tags:
ReFindNoCase("id:([0-9]+) .*stat:([a-z]+) ", retValue.shortMessage, 1, true)
Mack
ok thanks i have added the following, but nothing is written to the log file
<cflog file="smsTestCraig2" text="#ReFindNoCase("id:([0-9]+) .*stat:([a-z]+) ", retValue.shortMessage, 1, true)#">
That's because the ReFindNoCase returns a structure and the text
attribute expects a string (or something that can be converted to a
string).
Test the regular expression outside the cfc, in a simple test file to
make sure it's working properly and place the code inside the CFC
after that.
Mack
try this
<cfset st1=ReFindNoCase("id:([0-9]+) .*stat:([a-z]+) ", retValue.shortMessage, 1, true)>
<cfloop index = "i" from = "2" to = "#ArrayLen(st1.pos)#">
<cfset testval = testval & Mid(t,st1.pos,st1.len) & "|">
</cfloop>
<cflog file="smsTestCraig2" text="#testval #">
ok i have tried the following in a test file, but i just get 2 empty strings?
<cfset retValue.shortMessage = "echo: id:869990453 sub:001 dlvrd:001 submit date:0906301507 done date:0906301507 stat:DELIVRD err:000 text:">
<cfset testval = "">
<cfset testval = testval & Mid(true, st1.pos,st1.len) & "|">
</cfloop>
<cfdump var="#testval#">
The first parameter of the Mid function is not a boolean but the
string from which you want to extract the substring.
Mack
hi so what should the first value be?
i have tried st1?
