Hello everyone
I installed Adobe Acrobat on a Terminal Server. During the installation i choosed the language "German". Now every user has Adobe Acrobat in German.
Now i would check is there a language pack for adobe acrobat 8.0.0 in english so the user can set their own language to use adobe acrobat.
Is that possible or is there another good possibilty?
Thanks a lot for your help
Did you install Acrobat from Acrobat Pro EFG installer? If yes, then you can change Acrobat language by following the steps below:
1. Launch Acrobat.
2. Open the Preferences panel from Edit->Preferences.
3. Go to International tab.
4. Change "Application Language" to "Choose at application startup"; click OK.
5. Close and re-launch Acrobat.
Now you will get an option to select the language when Acrobat launches. Choose English.
Hope this helps!
-Amboo
Thanks for your support, it works without problems
thank AmbooS. it worked for me.
