I have been looking at code entirely to long and I keep getting a sql syntax error with the below code. Just wondering if anyone can see anything right off with the query before I go into more detail, I think I need some fresh eyes looking at it. This is being run against a MySQL server. TIA
select bcastreq.bcast_id, bcastreq.affiliate_id, bcastreq.subject, DATE_FORMAT(bcastreq.reqtimestamp, '%m/%d/%Y') as reqtimestamp, affiliate.affiliatename, bcastreq.affiliatetype_id, count(editbcastreq.bcast_id) as editcount, editbcastreq.affiliatetype_id
from bcastreq
left join editbcastreq
on bcastreq.bcast_id = editbcastreq.bcast_id
left join affiliate
on bcastreq.affiliate_id = affiliate.affiliate_id
group by bcastreq.bcast_id
<cfif Arguments.filtercolumn NEQ "" AND Arguments.filter NEQ "">
where #Arguments.filtercolumn# like '#Arguments.filter#%'
</cfif>
<cfif Arguments.gridsortcolumn NEQ "">
order by #Arguments.gridsortcolumn# #Arguments.gridsortdirection#
</cfif>
I'm not sure, can the group by clause come before the where clause like that. IIRC there is a certain expected order to the SQL clauses. I'm just not sure if this is required or just convention.
Ian's observation is correct. The where clause must precede the group by clause.
Also.
You are selecting 3 or 4 fields but only grouping by 1.
Is date_format a valid mysql function?
Thanks all. The date_format has been working fine. I did not start to have problems until I added the cfif statements to the query. I will try and give your suggestions a try today if I get a chance. Thanks again.
Thanks. Its always something simple. The location of the where clause was the problem. Much appreciated.
