Hello everybody,
I want to connect a Flex application to my Java services.
So I tried the "hello world" of GraniteDS:
http://www.graniteds.org/confluence/pages/viewpage.action?pageId=5668967
It works perfectly.
Now, more complicated, I want to use MY services
So:
a. I put my jar in lib directory
b. I update my services-config.xml with a new destination (my service)
c. I update the HelloWorld.mxml of the example:
<mx:RemoteObject id="srv" destination="myService" />
<mx:Panel styleName="Panel" title="Hello World Sample">
<mx:Label text="Enter your name:"/>
<mx:TextInput id="nameInput" />
<mx:Button label="Say Hello" click="srv.myMethod(nameInput.text)"/>
</mx:Panel>
I have one very important question:
myMethod has complex objects in parameters, not a simple String like the
example. It has in parameter one Java object that I made: "MyMethodRequest" and
this object has several attribute like login, password, locale and timezone. So
the question is: how can I call myMethod in Flex (with good param, not
"nameInput.text" param)? Morevover, I prefer to do that in Proxy.as rather than
mxml (I use PureMVC architecture)
If you have the solution, thank you very much!
Total Likes
You can make Alias Classe
go through the code which i attached .
Here im sending One String,One Float and One Integer values from Flex to Java.
Total Likes
