Good morning!
What I'm trying to achieve is linked to an earlier post this week (trying to launch 2 targets with the same trigger). The workaround solution is to insert a link in a drop-down text saying something like " Click here to view that area on the image below", but I can't get that trigger to work.
What I did:
The link from the drum won't cross past the drop-down text editor.
Anyway to make it work otherwise? I've been working at it since Tuesday but didn't achieve anything.
Thanks again for all your help, it is truly appreciated.
Hi there
Here is how I would do it. I absolutely HATE that little editing window. I do!
Construct the text you want to see along with the links and triggers in the main part of the topic. I generally do this right where the drop-down will ultimately be viewed. Then select it and cut to the windows clipboard.
Now open the pesky lil cuss of a window and select everything inside it. Paste what you cut earlier!
Did I say I dislike the little window? I thought I may have.
Cheers and Happy Thursday! Rick
Hi there
Helpful and Handy Links |
I'm starting to enjoy that little window as much as you! Thank you so much for the tip, works perfectly. I just have to figure out how to get the positioned text boxes to stay where they are. Otherwise works like a charm.
Again, you help is very appreciated. I'm getting kudos for my help prototype so kudos to you too!
Have a nice day!
Nath
