I have a large RH project that contains several conditional tags to reflect different products built on the same platform. I have recently converted this project from RH 7 to RH 8.
Before conversion, my tagged product names looked like this:
PRODUCT1PRODUCT2PRODUCT3PRODUCT4
After conversion, an untagged space was entered after each piece of tagged text. So, they now look like this:
PRODUCT1 PRODUCT2 PRODUCT3 PRODUCT4
It seems to compile fine EXCEPT when a tag is followed by un-tagged punctuation. This is a bit of a problem - since the find/replace doesn't seem to respect conditional tags, I have to go through a few hundred pages and edit out the spaces manually.
Has anyone experienced an issue such as this?
I haven't encountered the problem but it occurs to me that for something like this wouldn't you be better off using variables?
I have had this problem before (RH 9.2 and 2000) and never found a fix. It never gave me trouble when the conditional pair was followed by a space, only when there was unconditional punctuation.
(Hmmm...Unconditional Punctuation...good name for a technical editing company, that...)
Anyway, I am interested to hear whether using variables avoids the problem. We're about to upgrade to RH8, and variables are one of the new features I want to try.
You should not get this problem with variables as the topic contains a placeholder for the variable value. The space is not part of the topic.
I don't use tags a great deal but when I do, I have not seen this problem, I can't help but think it is something to do with exactly what is tagged.
I have also encountered this problem and have not found a solution. I am working with RoboHelp 8.
