Learn about Edge Delivery Services in upcoming GEM session
Version PDF with date/time
Avatar
Level 2
I need to archive my completed forms with a date/time stamp.  How do I do that in Workbench?
I'm using the Write Document service.  In the Input I put the name/location of the pdf in the Pathname Pattern
and check Make Unique.   When I try to use Xpath and add date/time to either Pathname Pattern or Make Unique
my form gets Stalled with the error of  "Not able to overwrite pdf".
Avatar
Former Community Member
Can you show how exactly are you appending the date time to the pdf using XPATH ?
if it is a windows environment, the date time pattern includes ':' and might not let the OS write the file.
Avatar
Level 2
The pathname pattern looks like this:  c:\eForms\CD\CDPaymentMaint.pdfadd-days-to-date(strDate1, days).
I tried c:\eForms\CD\CDPaymentMaint.pdf:add-days-to-date(strDate1, days) also and stalled again with this error:
Unexpected '\eForms\CD\CDPaymentMaint.pdf:add-days-to-date(strDate1, days)': org.jaxen.XPathSyntaxException: Unexpected '\eForms\CD\CDPaymentMaint.pdf:add-days-to-date(strDate1, days)'
Avatar
Level 10
Your pathname pattern is wrong.
If you use xPath, you'll have to use the concat function to concatenate two strings together.Also you need to use /process_data/@strDate1 to get to your variable and not just the variable name.
Something like concat("c:\eForms\CD\CDPaymentMaint.pdf",add-days-to-date(/process_data/@strDate1, days)).
Jasmin
Avatar
Level 2
I tried your sample and a couple variations: concat("c:\eForms\CD\CDPaymentMaint.pdf",add-days-to-date(/process_data/@strDat e1, days))
but kept getting:  Expected: ): org.jaxen.XPathSyntaxException
Any thoughts?
Avatar
try the right format...
Avatar
Try with the following options.
It worked for me.
you might want to make sure that the file you write is valid for.e.g
make sure that the variables have values.
strDate1 should be a valid value, and days should be a valid number.
i tried and found the result.
