HI
I am new to Robohelp. I created a project. None of the title or file names contain the & character but some of the headings in the topics do. When compile the project and create the index the character before the & and the & are truncated. For example, in heading1 I have T&E Items..... and the index entry shows E Items.
I searched help and the boards but could not find anything. I did check the HTML view and it correctly shows T&E. I am using version 8
Any help is appreciated
Kathy
So if your index keyword is This & That, you only see That in the index?
Use the camera icon above and show us some screenshots. Seems to work OK here in a quick test so I need to see exactly where you are seeing this problem.
thanks Peter
the index looks like this
and the topic h1 looks like this
thanks again
Kathy
I created them using the Smart Index Wizard and kept all default selections in the wizard
Try T & E rather than T&E.
thanks for the suggestion. Unfortunately I get the same results
Any other ideas?
Kathy
Import one of the offending topics into a brand new project.
Same problem?
same result
Zip up that small project and send it to me via http://www.cutesendit.com.
You can get my address from my site. Please include a link to this thread.
Oops. The answer was in your first post.
"None of the title or file names contain the & character but some of the headings in the topics do"
The index uses the topic title so no ampersand there and there will be no ampersand in the index.
I changed the topic title to include the amersand and get the same results. My understanding is that the file name cannot have special characters like &
I set the settings in index wizard to use just the topic title and this is what I get
Heading1 and the Topic Title reads T & E Items
Kathy
I'll take another look in the morning. It's late here in the UK.
No problem. I will try some different things and post if I find anything significant
I really appreciate your help
It is a bug in the Smart Index Wizard.
You can manually enter Index Keywords with an ampersand but and if your topic title is This & That and you use the Smart Index Wizard, it creates two keywords so This & That becomes
This
That
Two things.
- Personally I avoid the use of ampersands in anything like a topic title and topic heading and similar things in other applications precisely because of issues with special characters.
- You should report this as a bug. The wording highlighted blue above will be sufficient. Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
Thanks so much for your help Peter.
I am curious though as you said it worked for you???
The only way I could get it to work was to check the box that I wanted to verify each one and then add the new ones in teh wizard process. Is this the easiest way to manually add indexes
Thanks again
Kathy
It works with manually entered entries, that is when you type a keyword in the box at the top of the index pod and click the + sign next to it. You are still trying to use the Smart Index Wizard and that is where the bug is.
