14 Replies Latest reply on Oct 13, 2009 11:16 AM by xtraMike
    Rotation angle
    tony.bell
      How do you get the rotation angle of a piece of artwork?
      How do you rotate a piece of artwork?
      I have searched the sample code and all include files for all the suites for "Angle", "Rotate", "Matrix" and there is no call I can see which will easily do either of these.
        • 1. Re: Rotation angle
          Toto RoToTO Level 3
          You could take a look at Transfrom Art Suite.
          doc:
          Path art objects in Illustrator do not have transformation matrices associated
          with them. Although you may be inclined to do so, you will not be able to
          simply modify a path object’s current transformation matrix in order to
          transform it. Path art objects are simply collections of connected line
          segments.
          Incidentally, Text art, Raster art, and Placed art, do have transformation
          matrices associated with them. With these art types, you have to use specific
          accessor functions to get and set each object’s current transformation
          matrix.
          The Transform Art Suite
          The Transform Art suite exports a single function which transforms an arbitrary
          art object by a given transformation matrix. This function operates on
          all art types and therefore frees the developer from having to write special
          transformation routines for the different art type
          and use:
          AIAPI AIErr TransformArt (
          AIArtHandle art,
          AIRealMatrix *matrix,
          AIReal lineScale,
          long flags );
          and this to set matrix rotation:
          /**    Initializes a transformation matrix to a single rotation.
          @param m The matrix object.
          @param angle New angle value in radians.
          AIAPI void (*AIRealMatrixSetRotate) ( AIRealMatrix *m, AIReal angle );
          Thomas.
          • 2. Re: Rotation angle
            A. Patterson Level 4
            As an addendum: getting the rotation angle of art is mainly a matter of getting the matrix for the artwork and then pulling out the rotation from that. Getting the matrix an be tricky though. Every piece of artwork has a matrix associated with it somewhere, but other than specific kinds of art (e.g. kSymbolArt) I've never actually figured out how to get at this matrix. Its a little frustrating too, because there are some calculations you simply can't do without knowing that underlying matrix.
            As for applying a rotation, Thomas is dead on the money above. There are some art types that provide more direct ways of applying a rotation (again, kSymbolArt comes to mind) but for the general case you can't beat AITransformArtSuite.
            • 3. Re: Rotation angle
              tony.bell Level 1
              I have looked through nearly every AI funtion in all the suites.  There are over 150 which accept a rotation angle in radians or a transformation matrix as a parametr to manipulation artwork.  I cannot find a single one which will return the rotation angle or current transformation matirx to me for a text artwork.  Surely AI has to provide this somewhere.  There are many many instances which I need to know the rotation anlge of text so I can add/manipulate other art with it.
              • 4. Re: Rotation angle
                sanjaykr Adobe Employee
                You can use ITextFrame::GetMatrix to get the matrix of a TextFrame object. Ai does not store matrices on all kinds of objects. Though it definitely store matrices on Symbol instances, Bitmaps, Text, etc.
                For bitmaps you can use GetRasterMatrix of AIRasterSuite.
                For symbols you can use GetSoftTransformOfSymbolArt of AISymbolSuite.
                From these matrices you can get the rotation, scale, translate etc. via AIRealMathSuite APIs
                Sanjay Kumar,
                Illustrator Engineering.
                • 5. Re: Rotation angle
                  Thanks Sanjay -- always good to get some official word in here
                  If all artwork doesn't have a matrix stored, how does one get those rotated bounds we see sometimes? I mean, sure, you could ask for the rotated bounds using GetArtTransformBounds, but you need to know the angle at which to ask -- somehow the built-in AI annotator knows how to draw the edit handles at the right angle, but its not always obvious how to gernate that same bounding box.
                  For example, if you use the pen tool to draw some random polygon, then select it, it shows the bounds in AI. Now grab a corner and rotate it. The drawn bound handles also rotate. If I was given the handle to that polygon, I have no idea how I'd get those bounds. If I had the angle, sure, I'd just ask GetArtTransformBounds() with the angle. But given a simple path like that, how does one get the angle?
                  I'd always assumed there some kind of transformation matrix somewhere, but I guess that doesn't make sense for something like a path -- though I'd still like to know where the information is stored that indicates to the selection annotator how to draw that bounding box.
                  • 6. Re: Rotation angle
                    The bounding box rotation is a special case and handled via some inner details stored with the art which is updated along with the art transformation and I think that is something which needs a lot of polishing before it can be exposed via API.
                    Currently it can be assumed that it is not available, Though the rotation for rectangle/ellipses can be found out manually, by calculations via the anchor points.
                    Here is simple algo for rect
                    1. First identify if the path is a rect
                         a. check if the path has 4 anchor points
                         b. check if the length of 0-3 and 1-2 are same
                         c. check if the length 0 - 1 and 2 - 3 are same
                         d. check if length 1 - 2 and 3 - 0 are same
                         e. check if the in/out points of all anchor are equal to p
                    2. Now get the angle for 0 - 1.
                    The angle for the segment 0 - 1 is the angle for the rect.
                    Note: The length and angle can be found out using the suite AIRealMathSuite.
                    Hope it helps.
                    Sanjay Kumar,
                    • 7. Re: Rotation angle
                      Actually, this helps quite a bit to know. I few times I've been working on other aspects and having the idea lodged in my head that there was some matrix I simply didn't have access to would discourage me into thinking I didn't have all the tools I needed to do the work I was trying to accomplish. Knowing that this isn't the case (and I'll have to beat myself in the head next time I start to think it) will hopefully goad me into keep trying
                      As for the algo for determining the ellipse/rect angled bounds, that looks pretty good -- thanks!
                      • 8. Re: Rotation angle
                        tony.bell Level 1
                        Thanks.  At least I know the bounding box rotation specs are not available.  Although I think I can still figure out what i need.  Having compile Issue using the ATE namespace but when I figure them out I can use ITextFrame::GetMatrix to get the matrix/angle of the text art.  I can then rotate back to "0" and draw my rectangle around the text then.  When finished, I can rotate both back to the original angle.
                        • 9. Re: Rotation angle
                          tony.bell Level 1
                          I used the AITransformArtSuite as suggested.  Used example from sample code.  When I slect an art it does rotate it 45 degrees but throws it off the clipboard.  I do not see anyother parameter I am supposed to use.  Why doe it not rotate the art in place as you would manually?
                          AIArtHandle theArt
                          AIRealMatrix matrix;
                          AIReal angle, radians;
                          AIReal lineScale = 1.0;
                          long transformFlags = kTransformObjects;
                          angle = 45.0;
                          radians = sAIMath->DegreeToRadian (angle);
                          sAIMath->AIRealMatrixSetRotate (&matrix, radians);
                          error = sAITransformArt->TransformArt(theArt, &matrix, lineScale, transformFlags);
                          • 10. Re: Rotation angle
                            I believe adding a rotation of 45 degrees like that rotates it around the origin, but I could be mistaken. It's been a while since I messed with matrices, but I believe to add a translation to the origin, then concat on your rotation, then concat the reverse translation.
                            1 person found this helpful
                            • 11. Re: Rotation angle
                              tony.bell Level 1
                              Thanks Andrew.  That was it.  Had to change to the following.
                              error = sAIArt->GetArtBounds(theArt, &realArtworkBounds);
                              artCenter.h = realArtworkBounds.left + (realArtworkBounds.right-realArtworkBounds.left) / 2;
                              artCenter.v = realArtworkBounds.bottom + (realArtworkBounds.top-realArtworkBounds.bottom) / 2;
                              sAIMath->AIRealMatrixSetTranslate( &matrix, -artCenter.h, -artCenter.v );
                              sAIIMath->AIRealMatrixConcatRotate( &matrix, radians );
                              // move the object back to original position
                              sAIMath->AIRealMatrixConcatTranslate( &matrix, artCenter.h, artCenter.v );
                              Now if I can only easily find a way to get the angle of rotateion of a piece of text art
                              • 12. Re: Rotation angle
                                xtraMike Level 1
                                Hello Sanjar,
                                Hmm, I can't find any functions in the AIRealMathSuite APIs like
                                angle = GetAngle( inMatrix) or
                                scaleX = GetScaleX( inMatrix) or
                                scaleY = GetScaleY( inMatrix) etc.
                                do you have any sample code (or is it somewhere hidden in the various samples of the SDK istelf) or has everyone to reinvent the wheel :-(
                                Michael
                                PS.: In the moment I need only the angle of rotated symbols but who knows what I might need in the future :-)
                                • 13. Re: Rotation angle
                                  xtraMike wrote:
                                  Hello Sanjar,
                                  Michael
                                  The functions you want are:
                                  AIRealMathSuite::AIRealMatrixGetScale()
                                  AIRealMathSuite::AIRealMatrixGetRotate()
                                  The scale method gets you both x & y in one go (well, 'h' & 'v' ).
                                  • 14. Re: Rotation angle
                                    xtraMike Level 1
                                    And they are so prominently at the end of the file
                                    And thank you very mutch for opening my eyes.
                                    Michael who thought he has look through the whole file.
