Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Tunneling failed in Data Service 2.5.1
Avatar
Level 2
We created a set of application which all use Data Services
RTMP using port 2038. In the services-config.xml we set up in the
my-rtmp channel definition to use rtmpt as the protocol. All
applications are compiled with this service-config.xml.
For most users it is working fine, however for some of our
corporate user, behind restrictive firewalls, a connection to the
data services can not be made. The application throws a generic
send failed message.
Since we are using the rtmpt protocol, what can we do to make
sure our corporate users are able to use our applications?
-Rogier
1 Accepted Solution
Avatar
Correct answer by
Level 2
It seemed the problem was fixed. However, as we set rtmpt as
the only channel, our other users were experiencing a big drop off
in performance due to the tunneling.
I read a very good blog entry:
http://www.infoaccelerator.net/blog/post.cfm/setting-up-rtmpt-failover-on-lcds
where Andrew talks about using rtmpt as failover for those
users that cannot use rtmp.
We implemented the structure he described:
- channel definition for rtmp in services-config.xml
- channel definition for rtmpt in services-config.xml
- channel definition for polling-amf in services-config.xml
- define both channels as default channels in
data-management-config.xml in the order rtmp, rtmpt, polling-amf
Everybody was able to use the data services..
1 Reply
Avatar
Correct answer by
Level 2
