I'm trying to set up CFBuilder using CF8 with IIS 7 and virtual
directories for my web root and I can't seem to get the right settings ...
When I specify the doc root in the server setup ... I'm passing
c:\vir_dir ~ Then I add an existing project (1_CF) under c:\vir_dir_work\ ...
If I attempt to open the index page in the internal browser ... it works... but, if
I try to open any other page in the project it simply opens up the
index page in the internal browser ... Got any suggestions ... or does
CFBuilder only support c:\<cfversion>\wwwroot for a local server ... ?
Make sure you have given the webserver port same as port on which Virtual Directory is running. Also you given document root in Server dialog as location of virtual directory.
Check you able to see the sample URL generated is corrected for project created under virtual directory. To see the sample URL for project. Go to Menu Project->propoerties->ColdFusion Server Settngs->Sample URL.
Dohhh ... This problem was resolved as soon as I restarted the computer ....
Thanks for the advice ...
