I'm using Robohelp HTML 7 and can't publish a project. I was able to generate and publish it once, but can only generate now. After generating the webhelp, I click on Publish and then nothing. No error messages or popups. Zilch.
I'm able to generate and publish another project without any problems. I have tried emptying the folder on the server, as well as restarting RH and the computer. I have all required permissions to the server.
Anything else I shoud try? Has anyone seen this before? Thanks for your help!
Try creating a new layout, not a duplicate.
Can you connect to the target using an FTP program such as FileZilla?
After many unfruitful attempts, I ended up creating a new project. Luckily, it was not a very large one, so it didn't take up much time importing the .htm and .htt files into the new project.
I will however keep your suggestion in mind, using Filezilla, in case it happens again and I'm not that lucky with size file.
Thank you!
Nath
