I just cant seem to figure this out. How do i add a server in coldfusion builder.
jndi.properties
#Wed Jan 16 17:36:07 EST 2002
java.naming.factory.initial=jrun.naming.JRunContextFactory
jrun.naming.orb.port=900
jrun.naming.file.enable=false
jrun.naming.bind.enable=true
jrun.naming.orb.enable=false
jrun.naming.rebind.enable=false
java.naming.provider.url=localhost\:2910
java.naming.factory.url.pkgs=jrun.naming
jrun.naming.orb.host=localhost
jrun.naming.rmi.port=0
#jrun.naming.authorization=false
#jrun.naming.connection.filter=custom connection filter class name
security.properties
jrun.subnet.restriction=255.255.255.0
jrun.trusted.hosts=
Jrun-users set to default as shown
<jrun-users>
<encryption>false</encryption>
<user>
<user-name>admin</user-name>
<password>admin</password>
</user>
<role>
<role-name>jmcadmin</role-name>
</role>
<role>
<role-name>admin</role-name>
</role>
</jrun-users>
The server is online
Here are my settings for our network
Server settings-
Server Name: computerDomainName
Host Name: computerDomainName
WebServer Port:80
RDS User Name: admin
RDS Password: notTellin'
Remote Settings-
Namine Port:2910
Username:admin
Password:admin
The error says unable to communicate port 2910 means admin server is not running. Start the admin server on remote machine (check the doc how to install admincomponent on remote server). And on remote server update the security.properties with IP address of machine where your CFB is. Also you can specify * to make server start/stop irrespective of restrictions.
Okay I think I am getting somewhere. I run the batch file but the reason I wasn’t connecting was because It opens a batch file command prompt. I just closed it because I thought it was a single one time installation. So now I am leaving it open. But...
Now I can browse rds files but I am getting an error
, Error, 07/14 at 11:45:59, jrunx.rmi.RemoteInvocationHandler; local class incompatible: stream classdesc serialVersionUID = 2231785419166800282, local class serialVersionUID = -5340300571285905033
I also noticed I can't manage the cf8 service on cfbuilder
Heres my security.properties file
The internal ip address is 172.17.255.135 subnet mask 255.255.0.0
jrun.subnet.restriction=255.255.0.0
jrun.trusted.hosts=
What can the possible cause be?
P.S. I'm sure this so far is helping others.
Having the same problems here. Where do I find AdminServerComponents.zip? docs refer to it but no link is provided.
You can go here http://direct.adobe.com/r?xlncvnTEcvPnTElTvJvW
It was the address sent to download cf builder. Then you log in and it's the last link.
Hopefully you get farther than me!
Jinx! you owe me a coke....:)
thanks for the response.
Found the zip file. It's on this page if anyone else is as dense as I am and can't find it....
Ok, after installing the admin stuff on the remote server I get the same error you do:
Error, 07/14 at 02:28:03, jrunx.rmi.RemoteInvocationHandler; local class incompatible: stream classdesc serialVersionUID = 2231785419166800282, local class serialVersionUID = -5340300571285905033
Any luck on your end? Any CFBuilder devs out there?
I have tried many different ways. Do you have an admin service running? i cant image any other way. Because if i log off the server, it obviously will close out the command prompt and than i will get the JNDI error from before.
Yes admin service is running. Still can't figure it out.
Its known issue. But this should not cause any harm and functionality breakdown. If your receiving this message means CFB able to communicate with remote server.
Cross check the webserver port also make sure your able to ping to the server machine.
You are edited the security.properties with correct IPs.
Check the admin console for any exception at remote server.
If stil not able to connect send us the servers.xml file. Which is located in {workspace}/.metadata/.plugins/com.adobe.ide.coldfusion.server.
