I'm getting the following error in the Console when I add or refresh my server
[oolocal], (07/14 at 04:40:11): Server is available. Getting server settings from Server
[oolocal], Error, 07/14 at 04:40:12, Unable to fetch server mappings. Reason :null
[oolocal], Error, 07/14 at 04:40:12, Unable to get the log directory. Reason:null
cf8 standalone
webroot in c:\inetpub
I can browse datasource (so RDS is working)
Aaron
This is known issue. Unable to fetch server mappings. Reason :null.We are fixing this.
Just to check settings are collected successfully from the server. Create Project and attach server to the same. Open cfm and type <cfquery datasource=""> Should list the datasources.
Hi Aaron,
We are aware of this issue and has been logged. This error message is a harmless one and should not affect any functionality.
Bhakti
I have had the same error and the datasources do still list for cfquery. Could it have something to do with using a webroot external from the coldfusion default?
Yes, the datasources are listed
I am getting the same set of errors, is this a bug or have I setup the ColdFusion Builder incorrectly?
Your setup is correct. Please ignore these messages for now as they are harmless. Everything should work fine even if you get these messages.
-Bhakti!
I see, thanks
It's now more than a year later and I just installed CF8 as a localhost installation on my Windows 7 machine and i
t gets the same two error messages in the CFBuilder servers Console window after I setup a server entry in CFBuilder.
I can't believe that Adobe would ignore this problem for this long. How do I fix it?
