I'm about to use the RDS Dataview and when I right click and table to create an ORM CFC .. it asks me for the CFC location .. I choose a folder that's in my project and a new window comes up with a blank screen, nothing else happens.
This can happen if you have debugging enabled on the server. Can you please confirm if that is not the case?
Btw, this enable deugging is fixed in a later build by making changes in Application.cfc in the handler package of extensions.
Debugging is disabled.
Also I'm using Mac OS X 10.5.7
Just now a bug was reported regarding 'Framework' folder name being in mixed case in our extension code. That could be the same problem you are facing. If you want, you can lowercase all reference to 'Framework' in the extension code and try. We will of course be fixing this at our end.
