We are looking for code that allows us to enable web service and database connectivity rights into a form. We are using LiveCycle Forms 7.2 to render the XDP and merge data. Because we are merging data into the form, it has to be reader enabled through the code everytime it is presented to the user in our application.
These are the parameters we do have but we do not see one for web service connectivity.
usageRights[0] = com.adobe.document.pdf.DOCUMENT_SAVE.value;
usageRights[1] = com.adobe.document.pdf.FORM_FILL_IN.value;
usageRights[2] = com.adobe.document.pdf.FORM_EXPORT.value;
usageRights[3] = com.adobe.document.pdf.FORM_IMPORT.value;
usageRights[4] = com.adobe.document.pdf.FORM_ONLINE.value;
Anyone's help would be greatly appreciated
Total Likes
Wow Reader Extensions 7.2 was a long time ago. I remember there was a weird right that had to be set but I do not remember specifically which one. I have put a question out to some of my colleagues to see if we can find some code from way back then. If I find something I will let you know.
Paul
Total Likes
Sam Stickler
VP of Business Solutions
Novanis
15870 Dartford Way
Sherman Oaks, CA 91403
(P) 800-842-6634 Ext 3614
(C) 818-876-2983
(F) 818-337-7451
Total Likes
Well thanks for responding. We originally deployed this during the Reagan Administration so you are right it was awhile ago. Does Form.SubmitStandAlone ring a bell?
We have an externally facing Flex app that hosts an online form submittal. The form has a lookup feature. Our challenge has been the false positives we were getting when testing when we were sure the form was opening in Reader and not Acrobat.
Thanks again
Sam Stickler
Novanis
15870 Dartford Way
(C) 818-876-2983
(F) 818-337-7451
Total Likes
FormsOnline is the Usage Right that allows XFA Database & WebService (SOAP) connectivity
--Santosh
Total Likes
Thank you very much.
It works now as we have added the line you mentioned. Adobe support had said Forms.SubmitStandalone was the line. We actually added both just to cover our bases.
Total Likes
Thank you Santosh
We were told by Adobe that Forms.SubmitStandalone was the usage rights for connectivity. We added your answer and there's just to be on the safe side. Yours makes more sense. Don't why they don't create a usage rights that says FormsConnection or something more descriptive.
Anyway our app is now working and thank you again.
Sam Stickler
Novanis
15870 Dartford Way
(C) 818-876-2983
(F) 818-337-7451
Total Likes
