I just downloaded CF Builder for my Mac and I keep getting this message in my log files when trying to install:
Jul 16 13:24:06 ben-densmores-macbook com.apple.launchd[92] ([0x0-0x76076].cfbuilder_install[1075]): posix_spawnp("/Users/ben/Downloads/coldfusionbuilder_b1_install_mac_071309/cfbuilder_install.app/Contents/MacOS/cfbuilder_install", ...): Permission denied
I've tried launching the installer from terminal and that doesn't work either. Has anyone run into this issue?
Ben
What errors do you get when you launch from terminal? You have to use "Archive Utility" to extract the installer otherwise permissions may not be set properly.
- Vinu
Adobe
I get this error:
LSOpenFromURLSpec() failed with error -10810
I use Zipeg all the time to extract zip files and have never had an issue.
I think this all might stem from the latest update to Java that Apple released over the past few weeks. Searching on that error turned up either an issue with Java or an error in the info.plist file.
Ben
Okay, so for some odd reason Zipeg extracted the zip file with incorrect permissions. Not sure why, I've never had that happen before.
Doing
sudo chmod a+x /users/ben/downloads/cfbuilder_install.app/Contents/MacOS/cfbuilder_install
Fixed the issue.
Ben
