Show 2 replies
1. Re: Solution (at least for Flash)
N.D. Jul 29, 2009 8:48 AM (in response to franontheedge)Hello,
I have been working with this problem this morning and I believe I have a solution (at least for Flash import). Under Preferences/Metadata, uncheck both the options related to XMP. In addition, click the Metadata Display (also in Preferences/Metadata) and create a new default setting with all metadata schemas unchecked and save this setting as the new default.
Once I did this (bypassing the XMP metadata "feature"), I was able to import my .wav into Flash without problem. Remember, that you may have to close the file in Soundbooth before importing into Flash (like Flash, SB kind of hangs on to it).
2. Re: Solution (at least for Flash)
DannyBryant Aug 2, 2009 4:13 AM (in response to N.D.)Hello N.D.
This is most helpful. Thank you. Good workaround solution.
Danny
