OK..'nother weird one (I've encountered more weirdness in this project than in all others combined, I think!).
Index terms cross referenced to themselves aren't showing up in the compiled index.
If a term is cross referenced to another term, it shows up. If it's cross referenced to itself, it doesn't.
For example, The keyword(s) Automated Claims Transaction is crossed referenced to the acronym ACT, works just fine.
The keyword Reserving, cross referenced to itself because it has sub keywords under it, doesn't show up.
Reserving
this one
that one
other one
Reserving doesn't appear, much less the sub keywords under it.
We're using RH 7.00.145, if that helps.
Any clues as to what gives?
Jo
Hi Jo
The sub keywords should work without the Primary keyword being linked to anything.
I know it looks odd and I think in earlier versions years ago it may not have worked that way.
Cheers... Rick
Helpful and Handy Links |
Hi Jo
Cheers... Rick
Hot Damn! I didn't know it worked like that now! Used to, if that primary keyword wasn't linked to something, it didn't show up (of course, those were the days when you had to hack it in Notepad, too...).
It was SO cool, unlinking the main keyword, compiling, and seeing it in the index. YES!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you, Rick, once again you have saved my sanity!
Jo
