ShapeShift wrote:
> Ive tried reading about inner JOIN. but that does not
make much sence to me.
The MySQL documentation is good for understanding the syntax
of different commands. But it assumes you are already familiar with
JOINs, which you should be as they are a fundamental part of sql.
If you are not familiar with them, I would strongly suggest getting
a book on sql and/or reading some a high level tutorials. That will
give you an understanding of how joins and other sql concepts. Once
you understand those, the syntax is simple:
http://www.w3schools.com/Sql/sql_join.asp
(But to give a brief explanation in terms of your tables) The
concept of a join is simple: you have two or more tables that store
related information. For example, "subgroups" stores information
about products and "inventory" stores how many of those products
you have in stock. To retrieve information from both tables, in the
same query, MySQL needs to know how the records from each table are
related. In other words, which stock records belong to which
products. This is done through a JOIN .
It sounds as if your two tables are related through the
"subgroup" column. So you would JOIN the two tables on the
"subgroup" column. I do not know all of the columns in your
inventory table, but this might be an example:
SELECT sg.SubGroup, sg.Description, i.Sold
FROM subgroups sg INNER JOIN inventory i ON sg.subgroup =
i.subgroup
There are also different types of JOINS. The type of join you
should use depends on what information you need to return. But that
is something you can read about on your own.
HTH
