7 Replies Latest reply: Jul 22, 2009 4:04 PM by Sicundercover247 RSS
    DVD Export always returns jerky Video.
    Sicundercover247
      This problem is consistent across Encore, Premiere, and Adobe Media Encoder (Im using CS4). If I try to export to MPEG2 or even MPEG2 DVD i get this odd jerky playback.Its not just the DVD it even happens if I make an image or even if I just make a m2v.
      Ive tried every setting I can think of and have even tested other forms of video encodes but it only seems to be MPEG2 that is effected. Any ideas?
        • 1. Re: DVD Export always returns jerky Video.
          John T Smith CommunityMVP
          First, work through all of the steps here http://ppro.wikia.com/wiki/Troubleshooting
          If your problem isn't fixed, report back with the DETAILS asked for in the questions at the end of that link
          • 2. Re: DVD Export always returns jerky Video.
            mtechman Community Member
            I got the same reply to check
            99% of which is useless
            So check that the video off your camera  upper field first or lower field first is consistent with what ever your using to create your edited m2v.
            They must be the same ie; your camer records with upper/lower field first and you render with  same.
            • 3. Re: DVD Export always returns jerky Video.
              Bill Hunt CommunityMVP
              Unfortunately, if one does not provide any details, whatsoever, the users are hard pressed to offer any real "cures." That is why John posted his last line, about returning with the details.
              As the problem could be Field Reversal, your suggests might help. However, if the OP has, say a Matrox card (we just do not know), the the Field Dominance might need to be reversed from what would otherwise be normal.
              With complete details on:
              1.) System
              2.) Assets
              3.) Project
              someone can offer suggestions that might apply and solve the issue. Without them, we are all just guessing.
              Good luck to all,
              Hunt
              • 4. Re: DVD Export always returns jerky Video.
                Sicundercover247 Community Member
                Sorry it took me so long to get back, had alot to do and made sure i went completely over that check list.
                Took me a while to figure out the real problem, it was actually a pretty obvious problem and i cant believe i didnt see it earlier. The source file was 25fps and i was exporting it to a NTSC 29.97fps format. Apparently Adobe Media Encoder only duplicates frames to make it 29.97fps from 25fps. I did find that After Effects is able to do blends with the 3:2 pulldown however it kept failing halfway through.
                After extensive testing I found that Adobe does not offer a product that effectivly converts PAL to NTSC so instead Im left to attempt AVISynth or go buy DVFilm Atlantis to do the job.
                HERES MY SPECS ANYWAY
                1. The codecs used in your source clips = WMV9
                2. Premiere Pro
                  1. Version number= CS4 4.1.0
                  2. Installation language= En
                  3. Updates applied= All
                  4. Project/sequence settings
                3. Operating System
                  1. Name = Windows 7 RC Build 7232x64
                  2. Update/patch level
                  3. Installed language= En
                  4. Display resolution and color depth.1680x150 - 1280x1024 - 1680x1050 - True Color 32bit
                4. CPU type and speed - AMD Phenom 9850 2.5GHz
                5. Amount of memory (RAM) 8GB
                6. Video card
                  1. Manufacturer - BFG
                  2. Model - 8800GTX x2
                  3. Driver version - 8.15.11.8618
                7. Number of monitors (displays) in use - 3
                8. Audio card - SoundMAX Integrated Digital HD Audio
                  1. Manufacturer
                  2. Model
                  3. Driver version - 6.10.2.6400
                9. Each hard drive's capacity and space remaining
                  1. Disk setup (partitions used, raid configuration, what is where for OS/projects/media/scratch/audio)
                  2. 2x 10,000RPM Raptors RAID 0 138GB 40GB Free (OS and installed programs only)
                  3. 7,200 RPM WDHDD SATA 700GB 500GB Free Scratch Disk
                  4. 7,200 RPM WDHDD SATA 1.5TB 971GB Free Media Storage
                  5. 7,200 RPM WDHDD SATA 500GB 428GB Free
                10. Hardware capture device - NA
                  1. Manufacturer
                  2. Model
                  3. Driver version number
                11. Capture software - NA
                  1. Name
                  2. Company
                  3. Version
                  • 6. Re: DVD Export always returns jerky Video.
                    I use the Deskshare product, DigitalMedia Converter, and love it. IIRC, it's US$50.
                    Hunt
                    • 7. Re: DVD Export always returns jerky Video.
                      Ive tried both of those and they both copy frames. I realise Its never going to be perfect but I tried a buddies ProCoder 3 and that seems to work the best. TY for all the help.
