I am geeting the follwoing error when generating the chm file.
HHC4001: Warning:
The following alias line does not contain an '=' character separating the topic IDs: .
BMG_help.hhc
BMG_help.hhk
Throttling_Configuration.htm
SMS_Pull_Application_Management.htm
SMS_MMS_WAP_Messaging_.htm
Content_Provider_User_Management.htm
Quota_Management.htm
Content_Provider_Group_Account_Management.htm
Functionality.htm
Circle_Management.htm
System_Administration_.htm
Introduction.htm
BMG_User_Hierarchy.htm
Overview.htm
reference_documents.htm
Management_of_Services.htm
acronyms_and_abbreviations.htm
Multiple_User_Types.htm
Framework_to_Support_New_Interfaces.htm
MMS_Pull_Application_Management.htm
Multiple_Interfaces_Support.htm
Subscriber_Management.htm
Web_Interface.htm
External_Interfaces_Support.htm
Generation_of_CDRs.htm
Flexible_Billing_Definitions.htm
Message_Queuing.htm
Generation_of_Statistics_.htm
Subscription_Management.htm
Traffic_Reports.htm
Generation_of_Reports_.htm
Message_Scheduling.htm
Conversion_to_External_CDR_Format_.htm
Content_Provider_Profile_Database.htm
Service_Provisioning.htm
SNMP_Support_.htm
Management_of_Distribution_List_.htm
Push_Message_Flow.htm
Receiver_Agent.htm
OAM.htm
SNMP.htm
Processing_Agent.htm
Dispatcher_Agent.htm
Mediation_Gateway.htm
CDR_and_Report_Generation.htm
Law_Enforcement_Agency_(LEA).htm
Interface_Layers.htm
Network_Architecture.htm
Pull_Message_Flow.htm
Modifying_SMS_Quota.htm
managing_cp_account_quota_.htm
managing_cp_administrators.htm
viewing_content_providers.htm
modifying_cp_account_configuration.htm
creating_content_provider.htm
managing_content_provider_accounts.htm
modifying_wap_quota.htm
web-based_operations.htm
modifying_sms_messaging.htm
accessing_application.htm
modifying_mms_quota.htm
modifying_cp_user_configuration.htm
managing_cp_users.htm
Fatal Error: Unexpected error from Microsoft HTML compiler.
Finished compiling HTMLHELP in 39 sec(s)
Compilation complete.
why only to these htms i am getting the error?..what needs to be edited inthese htms?
Perhaps see if this thread helps:
This thread has not heped me as i ma not understaning this:
As a start I'd look at the alias file and add the missing =
character. and The alias file is the one with an .ali extension. It is a
text file so you can open it in Notepad and edit and save.
regards
prema
Date: Mon, 20 Jul 2009 19:12:22 -0600
To: vibhuteprema@hotmail.com
Subject: Robohelp compilation error
http://forums.adobe.com/thread/230382
I'll go through three options listed in the thread as possibilities:
1. There is an ali file used for context sensitive help, so it should only be necessary to make changes if this is set up for your application.
The = symbol separates the context (map) id and the help topic. The context id could be a number of things, depending on how your organisation set things up.
Examples:
AUDIT_TRAIL=Audit_Trail\Audit_Trail.htm
99187=Audit_Trail\Audit_Trail.htm
I don't use this myself (we have a custom solution), but possibly there could be an ID without a topic, or a topic without an ID, or maybe spaces either side of the = sign.
2. The ali file is saved in the wrong format, indicated by the symbols in the error - .
You would have to open the file and save in in ANSI format. I think you should just be able to open the file in Notepad, Save As and choose the Encoding for it.
3. The path to the project is too long. If you have a very long directory structure to get to your project, try moving a copy of the project to a directory something like c:\myproject and seeing if the compile works there.
HTH
Amebr
amber,
after the suggested chnages i am getting the follwoing error:
C:\BMG Admin Web Operations\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_1\BMG_help.hhp
Microsoft HTML Help Compiler 4.74.8702
Compiling c:\BMG Admin Web Operations\!SSL!\Microsoft_HTML_Help\BMG_help.chm
BMG_help.hhc
BMG_help.hhk
Introduction.htm
Overview.htm
Web_Interface.htm
SNMP_Support_.htm
Message_Queuing.htm
Traffic_Reports.htm
BMG_Message_Flow.htm
Receiver_Agent.htm
OAM.htm
SNMP.htm
BMG_Components.htm
Subscriber_Profile_Database.htm
Viewing_CP_Administrators.htm
Modifying_Content_Providers.htm
modifying_wap_privileges.htm
Creating_CP_Administrators.htm
modifying_sms_privileges.htm
modifying_general_privileges.htm
modifying_privileges.htm
modifying_mms_privileges.htm
Editing_CP_Administrators.htm
modifying_mms_messaging.htm
modifying_e-mail_to_sms_messaging.htm
modifying_wap_messaging.htm
managing_cp_user_quota.htm
modifying_messaging_configuration.htm
Creating_CP_Users.htm
Modifying_Content_Provider_Users.htm
Finished compiling HTMLHELP in 42 sec(s)
Prema
Date: Mon, 20 Jul 2009 23:33:44 -0600
Examples:
2. The ali file is save in the wrong format, indicated by the symbols in the error - .
HTH
Amebr
The path name is still a bit long. Try a new layout that generates to C:\bmg_chm\BMG_help.chm.
You'll note that only one other topic was compiled after your changes, so you didn't gain much:
Last topic compiled in Instance 1: modifying_cp_user_configuration.htm
Last topic compiled in Instance 2: Modifying_Content_Provider_Users.htm
Good luck,
Leon
