Greetings,
I have a remote server, running on port 80, that I want to connect to via RDS, but in IIS,
anonymous access is disabled and to view the website running on it, Windows authentication is required.
I have successfully connected to this remote server from CFBuilder via RDS only after disabling Windows authentication
and enabling anonymous access, but once I switch it back, CF Builder can't connect (401 Unauthorized error).
Is there any way to configure a Remote Server within CFBuilder, so that it passes my Windows authentication
credentials to it? Or, is there a workaround for this, other than disabling Windows authentication?
-Jose
The only work around for this issue that I found is turning off Windows Authentication for the virtual CFIDE directory you create. You can leave it on for all others. Thats what I ended up doing and its worked flawlessly since.
Yes, you are correct, your solution worked perfectly. Thank you!
