37 Replies Latest reply on Jul 27, 2009 1:17 PM by -==cfSearching==-
    Object Instantiation Exception. Creating Java Object
    TiGGi Level 1
      I am trying to implement CyberSource Simple Order API and I am getting an error on CFobject
      An exception occurred when  instantiating a Java object. The class must not be an interface or an abstract  class. Error: com/cybersource/ws/client/ClientException.
      So far I've placed the .jar file into :\ColdFusion8\wwwroot\WEB-INF\lib directory and on my cfpage I got:
      <cfobject action="create" type="Java" class="CyberSource" name="auth">
      Does anyone have any experience with CyberSource or the source of the error code?
      Thanks in advance!
        • 1. Re: Object Instantiation Exception. Creating Java Object
          -==cfSearching==- Level 4
          You need to include the class's package (ie path), as well as the class name.  For example:
          <cfset obj = createObject("java", "com.cybersource.ws.client.SomeClass")....>  .. instead of
          <cfset obj = createObject("java", "SomeClass")....>
          I do not use Cybersource, but you might review these references. The example on page 17 may be outdated, but it looks like a good starting point.
          http://www.cfug-md.org/meetings/Montreal_CreditCardPayments.ppt
          http://apps.cybersource.com/library/documentation/dev_guides/Simple_Order_API_Client_Java/ html/intro.htm#intro_14664_14665
          • 2. Re: Object Instantiation Exception. Creating Java Object
            TiGGi Level 1
            Thanks for the reply, I figured out why I am getting the error.  I needed to include the rest of the Java classes that come with the package.  As soon as I did that it worked, somewhat.
            Now I am getting another error:
            500
            ROOT CAUSE:
            java.lang.NoClassDefFoundError: Could not initialize class com.cybersource.ws.client.Signature
            It looks like when it tries to run a function inside the java class:
            <cfset myReply = auth.runTransaction(propsFile,myRequest)/>
            • 3. Re: Object Instantiation Exception. Creating Java Object
              Yes, the entire jar (and any supporting jars) must be placed in the CF class path. The error message indicates it needs a class named com.cybersource.ws.client.Signature but cannot find it.  Does that class exist in your cybersource jar(s)? Did you place all of the needed jars in the CF classpath?
              • 4. Re: Object Instantiation Exception. Creating Java Object
                dcsonka Level 1
                Did you guys manage to figure out the solution to that last error - the 500 ROOT CAUSE:
                java.lang.NoClassDefFoundError ??
                I had the same problems going forward and now have landed at this one as well. Any ideas?
                Thanks-
                • 5. Re: Object Instantiation Exception. Creating Java Object
                  I do not know if the OP ever resolved their issue.
                  NoClassDefFoundError is a generic error that basically means the class cannot be loaded.  The underlying reasons can vary.  Are you using the same jar listed above and how/where did you install the jar?
                  • 6. Re: Object Instantiation Exception. Creating Java Object
                    dcsonka Level 1
                    I had the sysadmin put the jar files directly into the coldfusionRoot/WEB-INF/lib directory. I had initially received the same original error the OP had, and it went away after copying all 4 of the required JAR files into the coldfusionRoot/WEB-INF/lib directory. Now, I get this 500 error.
                    • 7. Re: Object Instantiation Exception. Creating Java Object
                      What does the detail the error message say? Do they have a publicly available API?
                      • 8. Re: Object Instantiation Exception. Creating Java Object
                        dcsonka Level 1
                        The API files and documentation can be found in the matrix here:
                        http://www.cybersource.com/support_center/implementation/downloads/simple_order/matrix.htm lUnfortunately,
                        there is very scant information pertaining to plugging Coldfusion into the
                        Java version, its kind of tagged onto it.
                        Full error detail:
                        500
                        ROOT CAUSE:
                             at com.cybersource.ws.client.Client.soapWrapAndSign(Client.java:200)
                             at com.cybersource.ws.client.Client.runTransaction(Client.java:103)
                             at com.cybersource.ws.client.Client.runTransaction(Client.java:53)
                             at CyberSource.runTransaction(CyberSource.java:32)
                             at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                             at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                             at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                             at java.lang.reflect.Method.invoke(Method.java:597)
                             at coldfusion.runtime.java.JavaProxy.invoke(JavaProxy.java:87)
                             at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2272)
                             at cfcheckout22ecfm2002022632.runPage(/usr/local/apache2/htdocs/sfs/cybersource_api_test/che ckout2.cfm:42)
                             at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196)
                             at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370)
                             at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
                             at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279)
                             at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
                             at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
                             at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
                             at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:74)
                             at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
                             at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
                             at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
                             at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
                             at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
                             at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:126)
                             at coldfusion.CfmServlet.service(CfmServlet.java:198)
                             at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
                             at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
                             at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
                             at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
                             at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
                             at jrun.servlet.FilterChain.service(FilterChain.java:101)
                             at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
                             at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
                             at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
                             at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
                             at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
                             at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
                             at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
                             at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
                             at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
                        javax.servlet.ServletException: ROOT CAUSE:
                             at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:70 )
                        • 9. Re: Object Instantiation Exception. Creating Java Object
                          It should be easy to convert the java version to CF.  Did you properly install the client. It seems like that is required first:
                          See: Installing and Testing the Client
                          http://apps.cybersource.com/library/documentation/sbc/api_guide/html/
                          • 10. Re: Object Instantiation Exception. Creating Java Object
                            dcsonka Level 1
                            Yes, my sysadmin installed the java API client on the server, and did some
                            test API transactions to the test cybersource server, which were successful.
                            The Java API client has some script files to run the pure Java version of
                            the API to send a transaction to Cybersource. I was able to log into the
                            Cybersource business center to confirm that the transactions were received.
                            The next step was to integrate Coldfusion into the process. The coldfusion
                            option piggybacks on the Java Client, and generates a Java object inside
                            coldfusion from the Java API client on the server. The sample Coldfusion
                            templates which were provided with the API download were put on the server,
                            and then they were edited to point to the API properties file. After an
                            initial failure, I realized those JAR files needed to be made available in
                            the class path and we copied them over.
                            After that, the initial class not found exceptions ceased, but instead now
                            we get this 500 error.
                            • 11. Re: Object Instantiation Exception. Creating Java Object
                              What are the other jars?  Perhaps one of them conflicts with a version already in use by CF. It comes already bundled with a bunch of jars, sometimes used by other applications.
                              • 12. Re: Object Instantiation Exception. Creating Java Object
                                dcsonka Level 1
                                The following is an excerpt from some of the (limited) actual instructions
                                for the Coldfusion portion of the Java/Coldfusion Simple Order API for
                                Cybersource.
                                The ColdFusion directory contains the additional jar file, cybs-cfm.jar,
                                that
                                you need to include in your CLASSPATH in order to integrate the Simple Order
                                API for Java into your ColdFusion applications.  It also contains samples
                                for
                                both Name-Value Pair and XML clients.  They have been tested with ColdFusion
                                MX 7.
                                To add the CyberSource jar files to the CLASSPATH used by ColdFusion, edit
                                the
                                file /runtime/bin/jvm.config and append the full path of the
                                following jar files to the value of "java.class.path":
                                cybsclients14.jar OR cybsclients15.jar (depending on the JVM version)
                                cybssecurity.jar
                                xercesImpl.jar
                                cybs-cfm.jar
                                For example, on Windows, if you installed the Simple Order API in
                                "c:\Program Files\CyberSource Corporation\simapi-java-5.0.2", you would add
                                the
                                following paths:
                                c:/Program Files/CyberSource
                                Corporation/simapi-java-5.0.2/lib/cybsclients14.jar;c:/Program
                                Files/CyberSource
                                Corporation/simapi-java-5.0.2/lib/cybssecurity.jar;c:/Program
                                Files/CyberSource
                                Corporation/simapi-java-5.0.2/lib/xercesImpl.jar;c:/Program
                                Files/CyberSource Corporation/simapi-java-5.0.2/coldfusion/lib/cybs-cfm.jar
                                You will need to restart the ColdFusion application server in order for your
                                change to take effect.  On Windows, you will need to restart the "ColdFusion
                                MX 7 Application Server" service.
                                • 13. Re: Object Instantiation Exception. Creating Java Object
                                  ColdFusion 7 and 8 already include a version of xercesImpl.jar. That might be causing a conflict.
                                  1. Try removing that jar's path from the CLASSPATH + /runtime/bin/jvm.config file
                                  Update:  ie Remove this path
                                  c:/Program Files/CyberSource Corporation/simapi-java-5.0.2/lib/xercesImpl.jar;
                                  AND
                                  2. Remove the physical jar file from WEB-INF\lib
                                  Then restart CF to apply the changes.
                                  • 14. Re: Object Instantiation Exception. Creating Java Object
                                    dcsonka Level 1
                                    There is a much older conversation here involved the xerces JAr it seems:
                                    http://www.justskins.com/forums/coldfusion-java-guru-install-cybersource-java-api-79208-2. html
                                    Anyway - so back to your suggestions, from where should Coldfusion end up
                                    references the xerces JAR? If I remove it from the Classpath, and the
                                    jvm.config file, and remove the physical jar file from Web-INF/lib, where
                                    will it find it? Won't it be nowhere then?
                                    (thank you for your help btw - it is much appreciated)
                                    • 15. Re: Object Instantiation Exception. Creating Java Object
                                      dcsonka Level 1
                                      Oh, are suggesting to have the API Client reference the original xerces JAR file that Coldfusion had already? And to not use the one that came with the files in the API Client download?
                                      Also - we didn't make any changes to the class path at all, all we did was move the JAR files that came with the API download, into the coldfusionroot/WEB-INF/lib directory.
                                      • 16. Re: Object Instantiation Exception. Creating Java Object
                                        Yes, exactly.   Sometimes having two versions of a jar in the classpath causes the jvm to get confused and fall down.  By removing the extra version, hopefully it will eliminate the error. If indeed that is the problem here.
                                        That is okay about the classpath.  If you did not change the jvm.config file, removing the jar from WEB-INF/lib should do the trick.  (The reason is WEB-INF/lib is already in CF's classpath. So it knows it should load any jars it finds in that folder).
                                        • 17. Re: Object Instantiation Exception. Creating Java Object
                                          http://www.justskins.com/forums/coldfusion-java-guru-install-cybersource-java-ap i-79208-2.htmlis
                                          I read the older thread. One thing that is different about MX6 is that it did not ship with a version of xercesImpl.jar (As far as I know).  Both MX7 and CF8 appear to include Xerces-J 2.6.2 .  I took a quick look and that seems be the same version included with cybersource.  So hopefully it should be compatible.
                                          • 18. Re: Object Instantiation Exception. Creating Java Object
                                            dcsonka Level 1
                                            removed the xercesImpl.jar from the path /opt/coldfusion8/wwwroot/WEB-INF/lib/ and restarted coldfusion.
                                            Now getting the errors:
                                            500
                                            ROOT CAUSE:
                                            java.lang.NoClassDefFoundError: org/apache/xerces/dom/DocumentImpl
                                            • 19. Re: Object Instantiation Exception. Creating Java Object
                                              Weird. You are sure you rebooted?
                                              1. What version of CF are you using?
                                              2. Are you using the code CF sample from cybersource (ie checkout2.cfm)? If so, on which line does the error occur ?
                                              • 20. Re: Object Instantiation Exception. Creating Java Object
                                                dcsonka Level 1
                                                From that older thread - from the support person -
                                                "The xerces version that comes with the CDK is the important portion here, as
                                                it is required in order to sign the soap message with the RSA libraries that
                                                are part of the client. If any other xerces version is used besides the one
                                                included in the CDK, then it will fail with the java.lang.null that is commonly
                                                seen."
                                                would that be synonamous with the error I was just now getting after removing that xerces JAR?
                                                version is CF 8, my sysadmin knew it had to be rebooted
                                                • 21. Re: Object Instantiation Exception. Creating Java Object
                                                  dcsonka Level 1
                                                  I"m using the code samples provided with the API - it appears that it is failing at the exact same spot the OP indicated above. Inbetween dumping the Request and Response.
                                                  <cfdump label="Request" var="#myRequest#"/><br>
                                                    <cfdump label="Response" var="#myReply#"/>
                                                  • 22. Re: Object Instantiation Exception. Creating Java Object
                                                    I do not think so. Not unless you are seeing a null exception somewhere further down the chain. That comment refers to a NullPointerException (ie something is totally undefined) and the error you are getting is NoClassDefFoundError. The latter usually means there was a problem loading something, not necessarily that it could not be found.  But the causes vary.
                                                    But in any case, that version _should_ be okay.  According to the MANIFEST files the CF version seems the same as the cybersource version.   Did you check the logs? Maybe they contain a more detailed error.
                                                    • 23. Re: Object Instantiation Exception. Creating Java Object
                                                      dcsonka Level 1
                                                      Well, I mean I got the full error displayed on the page:
                                                      500
                                                      ROOT CAUSE:
                                                           at com.cybersource.security.asymmetric.signature.WsSecuritySign.signDocument(WsSecuritySign.java:46)
                                                           at com.cybersource.ws.client.Signature.sign(Signature.java:65)
                                                           at cfcheckout22ecfm2002022632.runPage(/usr/local/apache2/htdocs/sfs/cybersource_api_test/checkout2.cfm:42)
                                                           at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
                                                           at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
                                                           at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:70)
                                                      • 24. Re: Object Instantiation Exception. Creating Java Object
                                                        It almost seems like you were better off with the first error.  Where there any "Caused by:" details for the first error or just:
                                                        • 25. Re: Object Instantiation Exception. Creating Java Object
                                                          Hmm.. was the java version tested with the same jre used by ColdFusion?  It is a long shot, but I was wondering if the certificates (etcetera) were properly installed from ColdFusion's point of view.
                                                          • 26. Re: Object Instantiation Exception. Creating Java Object
                                                            dcsonka Level 1
                                                            Yeah, I couldn't find anything referencing a "caused by" in the preceding error reports.
                                                            The server that the java client and coldfusion code is running on, all uses the same JRE. That server is only used for coldfusion, and has just the one JRE installed.
                                                            If only thr Cybersource support staff was as responsive and helpful as you, you've been an awesome help, I just wish they could chime in and give some insight too.
                                                            • 27. Re: Object Instantiation Exception. Creating Java Object
                                                              Yes, sometimes it is tough dealing with Tech Support. Perhaps they just do not have much familarity they have with CF.  Though I was surprised to see they had any CF examples.
                                                              It is a real long shot, but have you tried running the pure java examples from CF.  In other words, create a wrapper class. Then call that from ColdFusion.  Unfortunately, I do not have an account with them. So I could only test the code up to a point.
                                                              • 28. Re: Object Instantiation Exception. Creating Java Object
        dcsonka Level 1
        That is an interesting idea! I'm going to see what they have to tell me,
        unfortunately they are also 3 hours behind me in timezone. If they have no
        credible solution, I may try your idea as a last resort. I'll keep updating
        this thread.
        • 29. Re: Object Instantiation Exception. Creating Java Object
        Yes, I do not know if it will work. But since you say it works from java, it might be worth a shot. Just be sure to use the same jars from java and CF so you are likely to get the same results.  (I would also be curious exactly which jars are needed to successfully run the project from java).
        I will keep an eye out for any updates.
        • 30. Re: Object Instantiation Exception. Creating Java Object
        dcsonka Level 1
        So, the customer support group said to update the jvm.config file to have
        the class path reference the JAR files, for it to work. I figured having
        them in WEB-INF/lib would have been sufficient, but they insisted it needed
        to be done.
        The sysadmin updated the jvm.config file and the preceding error did not
        occur (so I guess that is a small victory).
        Now however, we are getting a new error, relating to a certificate:
        Exception Message: sun.security.validator.ValidatorException: PKIX path
        building failed: sun.security.provider.certpath.SunCertPathBuilderException:
        unable to find valid certification path to requested target
        This doesn't look like a colfusion issue, offhand, but I'm not sure.
        • 31. Re: Object Instantiation Exception. Creating Java Object
        dcsonka wrote:
        ... I figured having
        to be done.
        I thought that too.  But obviously not if it resolved the error.
        I am not familiar with that last error. But it sounds like an issue with how the certificate was installed.
        http://forums.java.net/jive/message.jspa?messageID=133547
        • 32. Re: Object Instantiation Exception. Creating Java Object
        dcsonka Level 1
        The sysadmin got instructions from Cybersource on the certificate matter:
        • 33. Re: Object Instantiation Exception. Creating Java Object
        Was it different than what is described in the manual? Is it working now?
        • 34. Re: Object Instantiation Exception. Creating Java Object
        dcsonka Level 1
        It looks like it all basically came down to some steps that the sysadmin
        neglected to do during installation.1) Proper updating of the class path to
        point to the necessary jar files
        2) Proper installation of the root certificate for Cybersource
        Once those two things were done, I was able to make an API call from
        coldfusion.
        • 35. Re: Object Instantiation Exception. Creating Java Object
        Well, thanks for posting the follow-up (and I am glad you finally got it working!).
        • 36. Re: Object Instantiation Exception. Creating Java Object
        dcsonka Level 1
        Thanks to you as well- your help was most appreciated!
