RPC gives errors
Avatar
Level 1
I’ve created a AMF channel using the following block of codes:
var cs:ChannelSet = new ChannelSet();
var amfChannel:Channel = new AMFChannel("my-amf", "http://localhost:8080/lcds-samples/messagebroker/amf");
cs.addChannel(amfChannel);
This does not show any errors. But whenever I change ‘localhost’ by my machine’s IP, i.e.,
var amfChannel:Channel = new AMFChannel("my-amf", "http:// 192.168.1.102:8080/lcds-samples/messagebroker/amf");
it is throwing errors as follows:
Received fault: [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'http://192.168.1.102:8080/lcds-samples/messagebroker/amf'"]
I’m using JBoss 5. I could provide more details if it is required. Please help
Avatar
Level 4
Couple of checks/options you can try
-- Is the url valid http:// 192.168.1.102:8080 (The space is due to formatting or its there)
-- Is the server accessible at that url i.e. if you access http://192.168.1.102:8080 what do you see
-- JBoss by default binds to the local loopback. You would have to start JBoss with -b 0.0.0.0 argument so that it binds to all the interfaces
Avatar
Level 1
Thank you very much. Your solution provided a great help indeed. Thanks again.
Avatar
Level 1
I’m stuck to a point where port 2035 is working in the local server, but it does not work for another server. The code is as follows:
private var host:String = "xxx.xxx.xxx.xxx”;
private var port:int = 2035;
var rtmpChannel:Channel = new RTMPChannel("my-rtmp", "rtmp://" + host + ":" + port);
cs.addChannel(rtmpChannel);
the above code works where host in the above code is 192.168.1.102 but doesn’t work for 63.133.158.174
I need an urgent solution. Please help.
