Scenario-Simulation of a form fill interaction. User is instructed to fill 5 different fields pressing the Tab key to move between each item.
I set up the text box with the tab key as the shortcut, deleted the automatically provided click box and provide onscreen directions on what to type.
Running the program in Preview mode within CP "works" but the Tab key is mapped to the rewind button.Takes two hits on the Tab key to make this work
If I publish this the program halts at the first time the Tab key is used. I now must quit in order to get back the control.
Comments? Is there a better way to simulation a form fill interaction?
Hi there
Does the link below help at all?
Cheers... Rick
Helpful and Handy Links |
I think this gets around the issue at the published file level but I am still experiencing inconsistent behavior within the CP project file when I use the tab key as a shortcut. Nothing consistent but it seems the use of the Tab as a shortcut will "confuse" the project file when doing previews; especially when starting from within the project rather than from the first slide.
HI - Link from Capitiv8r does not work..any updated link anyone? 😉
This thread dates from over 10 years. Please, try to start a new question.
I will lock this thread.
