Hi -
I am using RoboHelp 7. The project is RoboHelp Pro. I am
using a custom window and skin.
I renamed a Help project (named "Test") using File >
Rename Project. Now when I generate WebHelp Pro output, the
following generated files appear in the output folder with the old
project name:
Test.glo
Test.hhc
Test.hhk
Test.htm
Test.lng
Test.ppf
Test.stp
Test.syn
Test_csh.htm
Test_hha.hhk
Test_rhc.htm
Things I have tried:
- searching the project directory for any file named or
containing the word Test or test. (None.)
- manually updated all SSLs to reflect the new project name
(they did not update with the rename action).
- shut down and restart, reboot, etc., go home and come back
the next day ;)
- searched the registry for references to Test (getting
desperate but treading carefully where I delete).
With all of this, the problem is not any clearer.
If I select File > View Primary Layout, the path in the
browser address window for the default topic is:
C:\...\!SSL!\WebHelp_Pro\Test.htm
If I select File > View From Server, it does show the
correct default topic and file name in the browser address window.
Anyway, the question is, for someone smatter than I, from
where could RoboHelp be picking up the old project name, and how
might I fix it?
