After converting files from RoboHelp 7 to RoboHelp 8, the link to the drop-down text editor changed font style. The words linked to the drop-down text should look like a hyperlink (blue, underlined), but some of them are gray highlighted, green, and underlined. Was this from the conversion? I tried to just highlight and change the font, but it already says it is blue and underlined. How can these by changed?
Any help is greatly appreciated!
Thank You!
Hi there
Normally that is governed by what your style sheet specifies. Have you double-checked that? Perhaps your style sheet has managed to become disassociated with the topic.
Cheers... Rick
Helpful and Handy Links |
Hello!
Yep, I did double check the style sheet and they are all set to the same .css. Any other ideas?
Thanks - A
Hi there
Sometimes the editor lies to us. Have you created output and examined the output? If not, try doing that. If you have, it's time to examine the code to ensure you don't have some sort of inline formatting applied.
Cheers... Rick
