RH 8 outputting a CHM or webhelp
Is it possible to use variables to switch images in and out when I compile?
I would like to use single source to create 2 guides for 2 audiences. While nearly all of the text content is the same, the screen shots need to vary by audience.
I know I can have popups/dropdowns to accommodate both audiences in one topic...just thinking of a more ideal solution...
Thanks.
Hi there
You may accomplish this using Conditional Build Tags. You tag the desired images, then exclude tags at compile time using a Build Expression.
Cheers... Rick
Helpful and Handy Links |
Of course! Thank you very much. In my attempt to simplify a process, I made things more complex...
