Is it possible to install 32 bit versions of CF Builder (and Eclipse) and ColdFusion 9 on a 64 bit Vista Business? The ultimate reason is to be able to prototype with MS Access. I guess than a 64 bit CF Builder (and Eclipse) on a 64 bit Vista Business will not run with a 32 bit ColdFusion 9?
You can install any version of CFBuilder posted in labs.Any install of CF Builder should work with both 64 bit and 32 bit version of CF Server .
Evelin
Thanks Evelin. So I can install 64 bit CF Builder and Eclipse on my 64 bit Vista and use a 32 bit ColdFusion 9 on the same machine to be able to see MS Access databases? Is it right?
Pierre
I am not sure if we have tried this but it should work. Are you facing any issues?
Thank you. I will try that.
Pierre
