Bad Timing
May 02, 2006 May 02, 2006
I'm just learning Captivate...so, when I'm recording (set at full motion 800x600) I make my way throught the clicks and such. Then when previewing the movie, not all the elements are lining up. For example, I click on one icon and it appears that I'm clicking on the one next to it. Sometimes, there doesn't even appear to be an icon to click on, yet there should be. It looks like there is a lag time along with a lack of registration (print term). Any ideas? I just read that full-motion is only for short bursts...not sure if this would cause all these issues.
Recording
601
Participant ,
This may be a result of using Enable auto recording from the Options/Recording Options... window. Captivate captures screens via event triggers. In other words, click the mouse and snap a picture...press a button and snap a picture, etc. The issue that often arises is that the capture process is quicker than the screen render so you start to see oddities like those you describe. If you are hearing the camera click sound before the screen fully renders, then this more than likely what is happening.
I use two options to counter this.
1. Turn off Enable auto recording and go the manual route by click Print Screen when you want a screen shot. The disadvantage of this is that you have to manually enter all the functionality, captions, etc. rather than having Captivate help. The advantage is that you have a great deal more control over the capture process.
2. Another method is to continue using auto recording, but to make liberal use of the Print Screen key to capture additional screens as you go. For example, click on an icon and Captivate takes a screen capture....now click Print Screen to take an extra screen after you are the screen has fully rendered. Just be sure not to move your mouse before taking the extra screen shot. In the Edit environment, you can simply delete any extra screens that you find you don't need.
May 04, 2006 May 04, 2006
Thank you! I am using the print screen to supplement the auto-recording process. This works well with my app. that has occasionally slow page render times. You are a gentleman and a scholar.
May 10, 2020 May 10, 2020
You have to load all the movies in turn, so that they are in a specific queue, and the system memory is not wasted.
Help resources
