Learn about Edge Delivery Services in upcoming GEM session
DataServiceTransaction
Avatar
Former Community Member
I'm running lcds on Jboss.
I'm trying to add an object on the server and push it to the client using the DataServiceTransaction class.
I do so by writing these lines:
DataServiceTransaction dataTrans = DataServiceTransaction.begin(false);
dataTrans.createItem(destinatin name, createItem);
dataTrans.commit();
but when running, i get the follow exception on the first line:
Unable to locate a MessageBroker initialized with server id 'null'
does anyone know how can i solve it??
thanks,
Liat
Avatar
Level 2
We you able to resolve this issue?
I am trying to update Data on client side from Server side using DataServiceTransectionClass. These updates are triggered at regular interval using EJB Timer API on JBoss App Server
I am facing similar issue following is stack trace
javax.ejb.EJBException: flex.data.DataServiceException: Unable to locate a MessageBroker initialized with server id 'null'
    at org.jboss.ejb3.tx.Ejb3TxPolicy.handleExceptionInOurTx(Ejb3TxPolicy.java:77)
    at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:83)
    at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
    at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
    at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
    at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:80)
    at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
    at org.jboss.ejb3.asynchronous.AsynchronousInterceptor.invoke(AsynchronousInterceptor.java:106)
    at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
    at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
    at org.jboss.ejb3.stateless.StatelessContainer.callTimeout(StatelessContainer.java:304)
    at org.jboss.ejb.txtimer.TimerImpl$TimerTaskImpl.run(TimerImpl.java:561)
    at java.util.TimerThread.mainLoop(Timer.java:512)
    at java.util.TimerThread.run(Timer.java:462)
Caused by: flex.data.DataServiceException: Unable to locate a MessageBroker initialized with server id 'null'
    at flex.data.DataServiceTransaction.begin(DataServiceTransaction.java:267)
    at flex.data.DataServiceTransaction.begin(DataServiceTransaction.java:293)
    at org.divy.scheduler.QueryScheduler.runQuery(QueryScheduler.java:58)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
    at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
    at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
    at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
    at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
    at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
    at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_17490623.invoke(InvocationContextInterceptor_z_fillMethod_17490623.java)
    at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
    at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_17490623.invoke(InvocationContextInterceptor_z_setup_17490623.java)
    at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
    at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
    at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
    at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
    at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
Avatar
Level 1
Hi DJ,     I think you have to install and configure JOTM first, see  http://www.nabble.com/LCDS---Tomcat---JOTM-Integration-td18761900.html     Cheers!     Martin Zach
Avatar
Level 1
Hi Liat,
Cheers!
Martin Zach
