I'm using the Current Date control on my form. This is OK for the date but I need the current time on a seperate control.
I see it has binding options in the Object section ie date, date and time and time but only date seems to work.
Does anyone know how I can set this to display the time only?
thanks
Paul
Total Likes
On the Binding tab there is a dropdown that allows you to define what goes into th efield. Choose Time and that is all you will get.
Paul
Total Likes
Yes, that should be the answer. But, as I said, when I select time only it still displays date and time.
In the 'Value' tab, I've been trying different settings. I set Type to User Entered options and Calculated options. I only get a blank unless I set this to "Calculated - Read Only" and set the runtime property to the only option available which is 'Current Date/Time'
So, there must be another setting that I need?
thanks,
Paul
Total Likes
But you are using a Custom Control called current Date which has a calculation in it to put the date in the field. Use a Dat and Time field and follow the same procedure.
Paul
Total Likes
