Hi All,
How to read images and text from pdf file?
Hi Dileep,
Though I am not 100% sure, I hope this can be acheived using "Adobe LiveCycle". Try refering the documentation.
hi,
any thing in cf8?
Hi Dileep,
Unfortunately in CF8 you may not able to perform those actions.
One side note though, In the upcoming "ColdFusion 9" (Centaur), <cfpdf> tag has been enhanced to perform operations like extracting data and images from a PDF document.
HTH
text should be doable, not so sure about images:
http://blog.cutterscrossing.com/index.cfm/2007/12/3/CF8-PDF-Manipulation-Pulling-Text-Out
http://www.coldfusionjedi.com/index.cfm/2007/7/24/ColdFusion-8-Working-with-PDFs-Part-7
there are also a few java libs (fairly easy to integrate w/cf) around that a
google search should turn up.
In that area, you might try jPedal as it is part of CF8 + CF9. IIRC, there was an example on the jPedal site about extracting images that may be worth a look.
thanks, i never suspected jPedal came w/cf. got any cf examples?
I have only worked with it from the java side of things. But I will see if I can whip something up. (If that evil place where they keep my paycheck does not interfere 😉
Well that was disappointing. I looked over the CF8 version and it seems signifigantly different than even the LGPL version. Not at all what I was expecting. Most of the key helper functions and/or classes are either private or not available at all. So you would still have to load a different version .. 😕
