1. Re: Load on user click
Rob Dillon Aug 5, 2009 4:56 AM (in response to rlinsurf1)If I'm reading all of this correctly, you just need to set the value of the variable "faFile" to the name of the sound file that you wan to use. Apparently this is in an external text file, "FlashAmp.txt". Open that file in a text editor and look for "faFile".
2. Re: Load on user click
rlinsurf1 Aug 5, 2009 5:12 PM (in response to Rob Dillon)Hi, Rob--
That looks like it's helped! Thank you.
Ok, but now I'm getting:
undefined Error opening URL 'file:///jeffrey/Downloads/mp3%5Fplayer%5Ffiles%5Fedit/undefined'
Here's the relevant code as I now have it. This is under Main Actions:
//load the FlashAmp data file and target the FlashAmp movieClip on the _root level... loadVariables("Sweethearts_On_Parade_BRGK.txt", _root.fa);Then:
function playSound () { if(!this.startLoad){ // sound not loaded this.startLoad = true trace(faFile) //use attachSound if the sound is in the library and linked. /* //attach the sound this.sound.attachSound('myLibrarySound'); //automatically call the sound loaded function this.onLoadSound() */ //use loadSound if the sound is an external .mp3. this.sound.loadSound (faFile, true); } this.playing = true this.sound.start (this.soundIndex / 1000) } //pause the current sound function pauseSound () { this.playing = false this.soundIndex = this.sound.position this.sound.stop () }Sweethearts_On_Parade_BRGK.txt and Sweethearts_On_Parade_BRGK.mp3 are both at the root level of the folder containing the .fla. And here's the line in the .txt file itself
&faFile=Sweethearts_On_Parade_BRGK.mp3
So I don't see what I'm doing wrong.
Message was edited by: rlinsurf1
3. Re: Load on user click
Rob Dillon Aug 6, 2009 5:43 AM (in response to rlinsurf1)The error is looking at this path.
jeffrey/Downloads/mp3 player files edit/undefinedIs this the path to Sweethearts_On_Parade_BRGK.txt" ?
In your playSound() function you have both the loadSound and attachSound methods in use. You only want one of these. You probably want to comment out the attachSound line.
I don't see it here, but you want to be sure that you are waiting for the text file to load before you start to use the contents. Do you have a load complete function for the loadVariables function?
4. Re: Load on user click
rlinsurf1 Aug 6, 2009 8:59 AM (in response to Rob Dillon)Hi, Rob--
No, I don't. I really think that may be the problem.
I've actually switched to using loadVars instead. Here's my current code:
myVars = new LoadVars(); myVars.load("http://charlesnewmanpubl.com/Sweethearts_On_Parade_BRGK.txt"); myVars._path = this myVars.onLoad = function (success) { trace(this._path) if (success) { trace (myVars.faFile); for( var prop in this ) { trace (" key " + prop + " = " + this[prop]); } } else { trace (" Error loading variables "); } }Then
//play the current sound function playSound () { if(!this.startLoad){ // sound not loaded this.startLoad = true trace("http://charlesnewmanpubl.com/media/" + myVars.faFile) //use loadSound if the sound is an external .mp3. this.sound.loadSound("http://charlesnewmanpubl.com/media/" + myVars.faFile, true)Could you tell me how to put in (and where) the load complete function? The .txt does of course load, and you can read the whole thing in the output -- but too late I think. It's fairly large for a text file, and so maybe that's why it's showing the .mp3 (faFile) as being undefined, as although that's the first var in the file, the whole thing hasn't finished loading when the error is thrown.
5. Re: Load on user click
rlinsurf1 Aug 6, 2009 7:46 PM (in response to rlinsurf1)Hi, Rob--
Ok. I've come along a little further.
I got this to work on it's own. This loads, checks, and then plays the file.
myVars = new LoadVars(); myVars.load("http://charlesnewmanpubl.com/Sweethearts_On_Parade_BRGK.txt"); myVars.onData = function(src){ myVars.decode(src) //trace(myVars.faFile); var faFile:String; var my_sound:Sound = new Sound(); if (myVars.faFile == undefined) { trace("not yet."); } else { faFile = myVars.faFile; trace(faFile + "!"); my_sound.loadSound("http://charlesnewmanpubl.com/media/"+faFile,true); clearInterval(param_interval); my_sound.onLoad = function(success:Boolean) { if (success) { my_sound.start(); //trace("Sound loaded"); } else { trace("Sound failed"); } } } }
My output just waits a bit, then displays
Sweethearts_On_Parade_BRGK.mp3!
But later on in the script, there's this function
}function playSound () { if(!this.startLoad){ // sound not loaded this.startLoad = true trace("http://charlesnewmanpubl.com/media/" + faFile) //use loadSound if the sound is an external .mp3. this.sound.loadSound("http://charlesnewmanpubl.com/media/" + faFile, true); } this.playing = true this.sound.start (this.soundIndex / 1000) }
When I run the whole thing, I at first immediately get
http://charlesnewmanpubl.com/media/undefined Error opening URL 'http://charlesnewmanpubl.com/media/undefined'
And then, after a bit
So it's hitting the playSound function before it's finished loading the data.
So it looks like I need to know how to call playSound only after myVars.decode(src). I realize I could just put the play code into the test at the top, but the problem is, the code at the top uses my_sound.xxx and all the rest uses this.sound.xxx. So I just don't know how to fit everything together.
6. Re: Load on user click
Rob Dillon Aug 7, 2009 6:41 AM (in response to rlinsurf1)If that first section using loadVars is working then leave it pretty much alone. I would move these two lines:
var faFile:String;
var my_sound:Sound = new Sound();outside of the onData() function. I would declare those two variables up where you declare myVars. This makes faFile a variable that is always available. It will get an initial value in the onData() function. So when you ask for it later in the playSound function, the variable will have a value.
You have a typo in this line:
this.sound.loadSoun d("http://charlesnewmanpubl.com/media/" + faFile, true);
If you move my_sound as I suggest, then you can use that variable throughout the movie. you won't need this.sound. If you have already loaded any given sound file into my_sound, then you don't need to load it again in order to play it. You should be able to just call my_sound.start(); when you want to play that sound again.
7. Re: Load on user click
rlinsurf1 Aug 7, 2009 4:01 PM (in response to Rob Dillon)Hi, Rob--
Thank you. I think I'm understanding the var use a little better now.
I actually had some help with this last night, so I'm not sure if that's what he did. The file is now playing, but I'm seeing other weirdness.
The data in the .txt is there not only to provide the variable of the file name, but a bunch of spectrum data about the file. When that data is used from the project folder, it shows an animated spectrum in the player, but it looks like we're not even getting to any of those functions now when loaded from the server.
As well, there's this line:
var playing : Boolean = false
Which is followed by a bunch of stuff like this:
} //sound has finished playing function onSoundComplete(){ this.playing = false this.rewind () if(this.loop){ this.playSound () } }The word playing is highlighted in blue, which means that it isn't a proper var, but somehow this whole thing works anyway. The problem is, I don't know where in this thing it's being used as a var, and where he means it as the parameter, playing.
Anyway, I hope you don't mind, but I think I need to post the whole bloody thing here, so here goes:
// Create a new LoadVars instance. var fa:LoadVars = new LoadVars(); // Give it a reference back to the container clip. fa.parent = this; // Start loading the text file. fa.load("http://charlesnewmanpubl.com/Sweethearts_On_Parade_BRGK.txt"); // Gets called after the text file has loaded (or if it fails to load) fa.onLoad = function(success:Boolean) { if (success) { // Note that the onLoad function is run in the LoadVars context which means you refer to the variables via "this" and not "myVars" if (this.faFile == undefined) { trace("faFile not found."); } else { trace("faFile has been found: " + this.faFile); // We use the parent reference we created before to access the sound object instance we created earlier. this.parent.init(); //this.parent.mp3.loadSound("http://charlesnewmanpubl.com/media/" + this.faFile, true); } } else { trace("Could not load text file."); } }; var clipInfo; // Information from Audio clip var clipDuration; // clip duration var snd; // Sound object to control volume var graphHolder : MovieClip var loadingTxt : MovieClip var sound : Sound var frameIndex : Number = 1 var ampIndex : Number = 1 var playing : Boolean = false //bad var var eqGraph : Boolean = true var soundIndex : Number = 0 var graphWidth : Number = 65 var graphHeight : Number = 30 var graphGap : Number = 1 var graphTopMargin : Number = 5 var frameLoopInt : Number var loop:Boolean = true var startLoad:Boolean = false //initialisation function function init () { var ref : Object = this //create an empty movieclip to hold our graph data this.graphHolder.createEmptyMovieClip ('graph', 0) //check for spectrum data to set graph type if (fa.spectArray.length > 0) { eqGraph = true } else { // use amplitude data eqGraph = false } //create our sound object this.sound = new Sound (); this.sound.onSoundComplete = function(){ ref.onSoundComplete() } this.playSound () } //sound has finished playing function onSoundComplete(){ this.playing = false this.rewind () if(this.loop){ this.playSound () } } //play / pause the current sound function playPause () { if (this.playing) { this.pauseSound () this.buttonPlay.icon.gotoAndStop('play') }else { this.buttonPlay.icon.gotoAndStop('pause') this.playSound () } } //rewind the current sound function rewind () { this.graphHolder.graph.clear () this.soundIndex = 0 this.ampIndex = 0 this.sound.stop () if (this.playing) { this.playSound () } } //switch between types of graph function switchGraph () { this.graphHolder.graph.clear () if (this.eqGraph) { this.ampIndex = 0 this.buttonSwitch.icon.gotoAndStop('eq') this.eqGraph = false }else { this.buttonSwitch.icon.gotoAndStop('amp') this.eqGraph = true } } //play the current sound function playSound () { if(!this.startLoad){ // sound not loaded this.startLoad = true //use loadSound if the sound is an external .mp3. this.sound.loadSound ("http://charlesnewmanpubl.com/" + fa.faFile, true); } this.playing = true this.sound.start (this.soundIndex / 1000) } //pause the current sound function pauseSound () { this.playing = false this.soundIndex = this.sound.position this.sound.stop () } //draw eq bar graph function drawEqBars () { trace("I'm here") //we're not getting here //works out where the sound is up to in terms of frames. var gFrame : Number = Math.floor ((this.sound.position / 1000) * fa.fps); //work out the width of one eq bar var bWidth : Number = (this.graphWidth - (fa.numBands + 1) * this.graphGap) / fa.numBands //clear the graph canvas from last frame this.graphHolder.graph.clear () for (var i : Number = 0; i < fa.numBands; i ++) { //work out the height of this bar var bHeight : Number = ((this.graphHeight - this.graphTopMargin) / 100) * fa.spectArray [gFrame][i] //draw the current bar as rectangle this.graphHolder.graph.beginFill (0xFAC096) this.graphHolder.graph.moveTo ((i + 1) * graphGap + i * bWidth, this.graphHeight) this.graphHolder.graph.lineTo ((i + 1) * graphGap + i * bWidth, this.graphHeight - bHeight) this.graphHolder.graph.lineTo ((i + 1) * graphGap + i * bWidth + bWidth, this.graphHeight - bHeight) this.graphHolder.graph.lineTo ((i + 1) * graphGap + i * bWidth + bWidth, this.graphHeight) this.graphHolder.graph.lineTo ((i + 1) * graphGap + i * bWidth, this.graphHeight) this.graphHolder.graph.endFill () } } //draw amplitude graph function drawAmpBars () { //works out where the sound is up to in terms of frames (fps is set in the #include file). var gFrame : Number = Math.floor ((this.sound.position / 1000) * fa.fps); //if the graph is at the end then send it back to the start if (this.ampIndex == this.graphWidth) { this.ampIndex = 0 this.graphHolder.graph.clear () } //work out the height of the current line var lineHeight = ((this.graphHeight - (this.graphTopMargin * 2)) / 100) * fa.amplitude [gFrame] //draw our current line as a rectangle this.graphHolder.graph.beginFill (0xFAC096) this.graphHolder.graph.moveTo (this.ampIndex, this.graphHeight / 2 + lineHeight / 2) this.graphHolder.graph.lineTo (this.ampIndex, this.graphHeight / 2 - lineHeight / 2) this.graphHolder.graph.lineTo (this.ampIndex + 1, this.graphHeight / 2 - lineHeight / 2) this.graphHolder.graph.lineTo (this.ampIndex + 1, this.graphHeight / 2 + lineHeight / 2) this.graphHolder.graph.lineTo (this.ampIndex, this.graphHeight / 2 + lineHeight / 2) //increment the line index ready for next frame this.ampIndex ++ } //frame looping functions function onEnterFrame () { //check if the sound is playing if (this.playing) { // allow playback to start before animating. This gets around the problem // of sound.position reporting > 1 while sound is streaming but not yet playing. if(this.sound.position > 100){ //check if we are showing the eq graph if (this.eqGraph) { //draw the eq graph for this frame this.drawEqBars () } else { //draw the amplitude graph for this frame this.drawAmpBars () } } } } } //everything's ready. lets go!Any help you can give me with this would be greatly appreciated.
8. Re: Load on user click
rlinsurf1 Aug 7, 2009 10:08 PM (in response to rlinsurf1)Hi, Rob--
I just found an online ref. for all AS operators, and playing isn't one of them. Maybe this is just a highlighting issue in CS4?
Anyway, if you could just help me troubleshoot why the data isn't being used, I would be very grateful.
9. Re: Load on user click
rlinsurf1 Aug 8, 2009 3:05 AM (in response to rlinsurf1)A little more progress. Again, we first load in a .txt which contain variables for the filename, and a bunch of spectrum data. What's not being used is the spectrum data.
I added this to test for what variables were present in the .txt.
trace (" variables loaded "); for( var prop in this ) { trace (" key " + prop + " = " + this[prop]); }Then a trace in the first function that calls for that data.
//check for spectrum data to set graph type if (fa.spectArray.length > 0) { eqGraph = true trace(fa.spectArray + "hi") } else { // use amplitude data eqGraph = false trace("Or not") }This is a bit of the output:
Or not key spectrum = ((0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0),(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0),(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0),
So there is no spectArray, but there is spectrum. Is his code right, or is there something else I should be looking for?
