I have updated two help systems from RH6 to RH8, and now the links to the help within the application are broken (browser either displays nothing or a 404 error when context-sensitive links are selected, or when attempting to open the project from the help menu within the app).
The help files are linked by the developers within the app. Does the upgrade change any settings that I am not aware of that could cause this behavior?
Any insight would be appreciated. Unfortunately I can't get a developer to look into the probelm until after next week!
I am not aware of anything being changed that would affect calls to the help. Check the problem occurs with all browsers.
This issue occurs on Safari and Firefox on Mac, and IE on Windows.
Does the help works correctly in those browsers if opened directly? In other words the problem is only when the application calls it.
The one in the mix that suggests to me that it is the way the developers call the help is IE in Windows. If that were an upgrade issue, I would expect to see lots of posts about the problem.
