I have never been very good at dates
I have a calendar that is not woking properly since I switched the db from access to sql Learning SQL also
<cfif isdefined("month")>
<cfparam name="startdate" default=#createdate(year,month,1)#>
</cfif>
<cfparam name="startdate" default='#month(now())#/1/#year(now())#'>
<cfset #enddate# = #dateadd('m',1,startdate)#>
<cfset #enddate# = #dateadd('d',-1,enddate)#>
<cfquery name="GetEvents" datasource=#dbname#>
Select * from tblCalendar
Where (Evt_Date >= ###dateformat(startdate,'mm/dd/yyyy')### AND Evt_Date <= ###datedateformat(enddate,'mm/dd/yyyy')###)
AND evt_approved = 1 and siteid='#siteid#' and scoutid=<cfqueryparam value="#url.scoutid#" cfsqltype="cf_sql_varchar">
</cfquery>
The problem is this.. It displays the current month just fine, however, when I click next or previous month, it does not change...stays on august.
Not sure what I am missing.
Thanks in Advance
Sharon
You are not using createdate the way the cfml reference manual describes it.
In your query, don't use dateformat. It returns a string, not a date object.
This might or might not help, but I think it reads easier
<cfif isdefined("variables.month")>
<cfset startdate = createdate(variables.year,variables.month,1)>
<cfelse>
<cfset monthNow = month(now())>
<cfset yearNow = year(now())>
<cfset startdate = createdate(yearNow, monthNow, 1)>
</cfif>
<cfset enddate = dateadd('m',1,startdate)>
<cfset enddate = dateadd('d',-1,enddate)>
Select *
from tblCalendar
Where Evt_Date >= #createODBCDate(startdate)#
AND Evt_Date <= #createODBCDate(enddate)#
</cfquery>
Thank you, It did clean things up a bit but did not fix the problem.
On the calendar, when someone clicks next, it passes the next month in the url ., ie month number 9
problem is, query is not pulling it, its stil pulling the month of 8 and as I previously stated dates and me do not mix. hurts my head just looking at it.
<cfelse>
</cfif>
<cfquery name="GetEvents" datasource="smdscout">
Select *
from tblCalendar
</cfquery>
You are using isDefined on the variables scope instead of the url scope. Unless you have some code that creates variables.month, the function will always return false.
Well, I did a short/long cut to fix the problem...but thank you dan for the hint. the variable for month was not be set.
