quote:
Originally posted by: gandalf458
Thanks guys. I got as far as drawing the circle but didn't get the rest.
Cheers G :)
Here is the 2016 Answer to the question using InDesign CC 2015...
1) Place the Photo.
2) Object -> Convert Shape -> Ellipse
Start with a square photo to get a perfect circle. If you need to resize the picture, be sure that Auto-fit checkbox is enabled on the tool bar. To change the cropping, disable the Auto-fit checkbox. Use the Shift-Key to maintain a perfect circle when dragging.
That was crazy easy! Thank you! Perfect!
Do you know the 2018 InDesign answer?
Yeah select the image, go to the right panel where pages, layers, links, etc. is found. Click pathfinder. In the convert shape area press the circle button
Different ways to acheive this in Fireworks, one way is to draw a circle with no fill line the photo up with the circle > copy image > select circle > paste inside
