Hello!
I have a .css (attached) that is related to all files of my project to Robohelp. Sometimes the changes the Robohelp .css removing various tags. How to disable this option in the tool?
Thanks.
Can you give us some more detail? What style changes are being made and tags are being removed?
Read the RoboColum(n).
When did your css change?
RoboHelp will change your CSS when you edit it from the build-in css editor and RoboHelp changes your css when you generate your output.
Use an external editor for editing your stylesheet (Notepad++ is a good editor).
Greet,
Willam
Didn't we look at this CSS once already, somewhere else?
The major issue I see is this: "#menu ul li a:link {"
My recommendations:
These style settings might be OK if you were creating your own web site that would only be interpreted by HTML and CSS protocol on web browsers. On the contrary, you're asking RH to:
You must, therefore, not only allow RH to adjust things accordingly, but also adapt your working practices to accomodate that environment.
Good luck,
Leon
