adding multiple row and column data with a form
Apr 24, 2006 Apr 24, 2006
I need to add multiple row and column data to a database using an online form and am not sure what the best method of data entry and inserting would be.
The data should look like this:
COLUMN1 COLUMN2
var1 var1
var2 var2
var3 var3
etc.......
When creating the form should I have individual text fields for every var or would it be better to have a text field where they list the data. I'm just not sure where to start.
Any advice would be great.
Advanced techniques
403
Contributor , Apr 25, 2006 Apr 25, 2006
You can use row numbers in your field names to associate the columns with a particular record. For example, let's say you want 5 rows to enter last names and first names:
<CFSET maxrow = 5>
<CFLOOP INDEX="rownum" FROM="1" TO="#maxrow#"><CFOUTPUT>
Last name: <INPUT TYPE="text" NAME="lname#rownum#" SIZE="25">
First name: <INPUT TYPE="text" NAME="fname#rownum#" SIZE="15"><BR>
</CFOUTPUT></CFLOOP>
This will give you a series of fields such as lname1, fname1, lname2, fname2, etc.
In your form, yo...
Individual text fields for every var is the way I would do it.
I don't think I was clear in my original explanation. I need all the variables in Column 1 to go into the same column in the database and of the variables in Column 2 to go into another column in the database. If I create a unique text field for each variable won't they each need their own column in the database? I need them to be inserted into one column, and the variables in Column 1 correspond to the variables in Column 2. I know I need to do a cfloop statement, but I need a little more guideance on how to set up the form.
Contributor ,
So the different columns are grouped with rows?
Contributor ,
<CFSET maxrow = 5>
In your form, you can also include a hidden field to indicate the number of rows.
When you process the form, you loop again to insert each row:
<CFLOOP INDEX="onerow" FROM="1" TO="#Form.numrows#">
<CFQUERY NAME="addRec" DATASOURCE="mydsn">
INSERT INTO mytable (lastname, firstname)
VALUES ('#Form["lname" & onerow]#)', '#Form["fname" & onerow]#')
</CFQUERY>
</CFLOOP>
Regarding:
No.
As long as you know the name of the form field and what you are supposed to do with it, write your code accordingly.
Documentation
