I need help regarding this function. I have made an application form. I have a section with a few text boxes (not fields) that are for instructional purposes only. When the application is printed these boxes should not print. I have selected the Visibly (Screen Only) for these text objects yet that still print and I cannot find anything in the help features that can tell me why and tell me how to fix it. I have made several changes to this application form from the original and in the original template the Visible (Screen only) worked for these text objects. So I don't know what I have done and how I can fix it. Can someone help me? Thank you!
Total Likes
Can you psot your form so we can see what is happening as well please indicate which version of Designer and Reader/Acrobat you are using.
Paul
Total Likes
Attached is the file as requested. I have Acrobat 9 Pro/Life Cycle Design ES. I have also stumbled into a problem that users can not save a copy. So when its submitted its a blank form. How do I give them the right to save? Should be an easier solution but so far I have been unsuccessful to fix it. thank you for your help.
Total Likes
Never mind about the blank forms. I have figured that one out. Thanks.
Total Likes
