2 Replies Latest reply on Apr 25, 2006 7:37 AM by Deaf Mike
    Active Content Issue
    Deaf Mike Level 1
      http://clerccenter.gallaudet.edu/temp/various-flash-tests/flash-fix-test.html
      hi - go to the above. i followed the instructions and info from other postings and am able to get an HTML page generated by Flash to take care of that IE browser active content problem.
      http://clerccenter.gallaudet.edu/temp/various-flash-tests/fix-embedded.html
      then go to the above link. this is the SWF file placed onto a blank HTML page with Dreamweaver. Obviously, the active content fix does not work now. so my question is how do i get this to work when i want to place flash content on my page through using DW?
      I read somewhere that i may need to link up the JS file. can someone help me with that? PS - i'm not good with writing JS code.
      thanks.
        • 1. Re: Active Content Issue
          Level 7
          Deaf Mike,
          > JS code.
          The IE Active Content issue is a pretty popular one lately, as you can
          imagine. The easiest, most convenient solution I know of is to use a tiny
          JavaScript application called FlashObject. -- Scratch that. I just learned
          that the developer felt compelled by Adobe to change the name of his free
          product to SWFObject. (Sigh.) Okay, so it's SWFObject, then. And a
          beautiful piece of code it is. Give it a shot, Mike. Very easy to use.
          But if you have questions, write back.
          http://blog.deconcept.com/swfobject/
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Active Content Issue
            Deaf Mike Level 1
            David,
            thanks so much for that link. i'll give a try or have our JS person help me figure it out.
