1. Re: Text Manipulation and Variable Data in Photoshop
c.pfaffenbichler Aug 13, 2009 11:34 PM (in response to Bill Vojtech)I’m unfamiliar with Direct Smile.
But for text-manipulation in Photoshop You might want to consider converting the Text to a Smart Object which can then be warped or treated with the Distort-Filter Displace, all the while maintaining the text-layer within the SO and thusly its editability.
And if I remember correctly one can even make Liquify applicable as a Smart Filter, but one would have to save the Mesh separately … possibly too problematic a solution.
Or You could go via Illustrator which offers Envelope Distort (which provides a grid-based »plasticity«) and then embed the result thereof as a SO in the Photoshop-file. Unfortunately Illustrator doesn’t Script as comfortably as Photoshop in my limited experience and Envelope Distort my be unscriptable altogether.
But if I understand correctly You will want to automate all that stuff, so maybe You should check out the respective Scripting-Fora.
