RemoteObject Destination configuration problem
Avatar
Level 1
I have created a very simple 2 state mxml file(attached
below) where you submit a name which is passed to a RemoteObject
which appends "Welcome " to the input string & returns the
whole string back.
The java class which does this is,
package samples.SimpleRemoteObject;
public class Echo {
public Echo(){
public String getString(String str){
return "Welcome " + str ;
I have added the following to flex-remoting-service.xml under
c:\tomcat\webapps\flex\WEB-INF\flex,
<destination id="EchoString">
<properties>
<source>samples.SimpleRemoteObject.Echo</source>
</properties>
</destination>
The <default-channels> & <adapters>
definition was already there.
I also put Echo.class under
C:\tomcat\webapps\flex\WEB-INF\classes\samples\SimpleRemoteObject.
After Tomcat(v5.5.9) is started, it correctly loads the
initial page
at
http://localhost:8080/flex/SimpleRemoteObject/SimpleRemoteObject.html
but after I click on submit, I always get "Error: Unknown
destination 'EchoString'". I have tried renaming the destination
names but there is no change in behavior.
Please let me know what am I doing wrong. All the samples are
running fine
though. This is my first attempt on doing something with
Flex.
Aejaz
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
xmlns="*" layout="absolute">
<mx:Script>
<![CDATA[
import mx.rpc.events.*;
import mx.collections.*;
import mx.controls.*
private function getNameHandler(event:ResultEvent):void
Result.text = event.result.toString();
currentState='TargetState';
private function faultHandler(event:FaultEvent):void
Alert.show(event.fault.faultstring, "Error");
</mx:Script>
<mx:states>
<mx:State name="TargetState">
<mx:RemoveChild child="{button1}"/>
<mx:RemoveChild child="{formInput}"/>
<mx:RemoveChild child="{label1}"/>
<mx:AddChild position="lastChild">
<mx:Label x="99" y="130" width="265" height="28"
id="Result"/>
</mx:AddChild>
</mx:State>
</mx:states>
<mx:RemoteObject id="SendStringBack"
destination="EchoString" showBusyCursor="true"
fault="faultHandler(event)">
<mx:method name="getString"
result="getNameHandler(event)">
<mx:arguments>
<str>
{formInput.text}
</str>
</mx:arguments>
</mx:method>
</mx:RemoteObject>
<mx:TextInput x="119" y="129" id="formInput"/>
<mx:Button x="119" y="170" label="Submit" fontSize="13"
id="button1" click="SendStringBack.getString.send()"/>
<mx:Label x="119" y="86" text="What is your name ?"
width="160" fontSize="15" id="label1"/>
</mx:Application>
Text
Avatar
Level 2
Did you add the compiler argument?
-services
c:\tomcat\webapps\flex\WEB-INF\flex\flex-remoting-service.xml
under Project -> Properties -> Flex Compiler
Avatar
Level 1
Thanks for your reply. The value present in the "Additional
compiler arguments" field is,
-services
"C:\tomcat\webapps\flex\WEB-INF\flex\flex-enterprise-services.xml"
when I change it to,
-services
"C:\tomcat\webapps\flex\WEB-INF\flex\flex-remoting-service.xml"
I start getting,
exception 'java.lang.RuntimeException' while setting variable
'compiler.services'. It seems that the only value allowed is
"C:\tomcat\webapps\flex\WEB-INF\flex\flex-enterprise-services.xml".
I tried putting,
"C:\tomcat\webapps\flex\WEB-INF\flex\flex-enterprise-services.xml;C:\tomcat\webapps\flex\WEB-INF\flex\flex-remoting-service.xml"
it gave me "Unable to open
Please let me know what does setting,
-services
do & can't it be done manually.
Aejaz
Avatar
Level 2
You'll get that exception if the services xml file is not
formatted properly. The current parser is not very stable I guess.
I think you should modify the original flex-enterprise-services.xml
file to include your new destination and use that for the
compiler.
Avatar
Level 2
The -services option should always point to the top level
configuration file which is flex-enterprise-services.xml.
-services
If you open up flex-enterprise-services.xml, you'll see that
you can point to additional configuration files using the
'service-include' xml tag. In the case of the default application,
this already includes flex-remoting-service.xml.
flex-remoting-service.xml is only a subset of the configuration
information required by the compiler and cannot be used
separately.
Avatar
Level 1
has this issue been resolved? ...... I am having a similar
problem, but am getting the following error:
Channel.Connect.Failed error NetConnection.Call.Failed: HTTP:
Status 404
Because the uri for the RO destination channel (my-amf) is
parsing without the context.root:
http://localhost:8000//messagebroker/amf
perhaps you are having a similar problem. Please let me know,
thanks.
Avatar
Level 2
is parsing without the context.root:
If you're compiling from the command-line, be sure that you
specify the context root using -context.root /samples.
This may also be configured in flex-config.xml, if using.
Avatar
Level 1
I meet the same problem. But if i publish my project undex
samples webapps it works.
So i compared both webapp (/flex and /samples) the major
difference is in flex-enterprise-service.xml.
I set <security-constraint> in comment and...it works
Wish it can help you
Best regards
Eric
