1. Re: Does Adobe allow fallbacks to CS3 from CS4?
John T Smith Aug 14, 2009 7:10 PM (in response to sarmour2)If you are inside 30 days, you may return for a refund (Call Adobe)
If outside 30 days... you should still call Adobe to find out if they will give you an install # for CS3
2. Re: Does Adobe allow fallbacks to CS3 from CS4?
Colin Brougham Aug 14, 2009 7:19 PM (in response to sarmour2)I don't use Cineform, so this is merely conjecture, but isn't there a new-ish version of the codecs/plugins that is CS4-compatible? I seem to remember others posting that older versions of Cineform's products wouldn't work in CS4, and that an update was necessary (again, I didn't follow too closely, not being a Cineform user). Or is it the new version that's giving you problems? If so, you might want to contact Cineform, as CS4--especially with the last update--has been pretty stable and usable.
3. Re: Does Adobe allow fallbacks to CS3 from CS4?
Bill Hunt Aug 16, 2009 10:47 AM (in response to Colin Brougham)Colin,
There was talk that Cineform was working on a CS4.1 version. I just do not recall hearing whether it has been completed yet.
As you suggest, contacting Cineform will likely get updated info and maybe a cure to the OP's issues.
Good luck,
Hunt
