I'm baaccckkkk......
'Nother question (and I always seem to have the Really Weird Issues).
The client uses RH to create training tools for new hires. I've created a shell project, already set up with the templates, style sheets, common topics, basic TOC, index, graphics, etc. The idea is the developer copies the shell project, renames the directory of the copy to the new "tool" name, opens the project, and immediately selects File > Rename Project and gives it the name of the new tool.
EVERY time RH loses files. They're still in the directory when you look in Windows Explorer, but RH doesn't see them, they have to be imported (and all the broken links vanish!). It's always the same files, too. I've experimented several times, it always happens, always the same files. I'm creating a job aid for the client to use in developing the new "tools" and when I renamed it, nothing was lost.
Any clues as to what's causing this? I've got it documented in the job aid as an annoying "gotcha" but if I can figure out how to keep it from happening we'll all be a lot happier.
Jo
Hi Jo
Anything special about the names of the files that get missed? Odd characters or anything like that?
Perhaps you are seeing a bug we haven't encountered yet.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Nope, Rick...no special characters they all have a file_name.htm configuration.
That would be my luck, wouldn't it, finding the one undocumented bug that is so rare hardly anyone ever encounters it!
Have you tried renaming the CPD and/or peeping inside it with Microsoft Access to see what's going on?
--- Derek
Apparently it's not the victim of an evil cpd file, Derek. I copied the master, renamed the cpd file, opened it, renamed it, same issue. When I get a few extra minutes I'll try looking at it in Access and see if I can find anything obvious - and it would have to whack me one, don't think I've ever actually used Access, been ages since I even opened the program!
Jo
Hi Jo
Yes, I was very skeptical of the suggestion about the .CPD. Had it been related, it would be sufficient to kill it and let RoboHelp rebuild it. No need to go spelunking.
Cheers... Rick
Hey Jo, can you possibly give us a scenario to test? Perhaps something listing your topic names, folder names, topics missed, etc?
Maybe even make a copy of your project, strip away any real content from topics and attach here as a zip so we might download and test?
Just thinking out loud... Rick
Well, don't know what the problem was, but I've nixed it. Got permission to strip content and submit the project. So, copied the project, renamed it, and it lost the same files it always does. Not the folders, just the contents. As a sidenote, these particular topics are common to all the projects, and have been copied back and forth umpteen times. The lightbulb (a politically incorrect one, can't STAND those ghastly CFL ones!) came on; just on a hunch, I deleted the topic, said "no" to keep my links (which immediately created all sorts of broken links, of course), then recreated the topic (thereby fixing the broken links, the whole point of saying no...) and pasted the content back into the topic. Did a trial run of copying, opening, and renaming, ant the recreated topics remained in the project. So, there must have been something in the coding of the topics that was....um...messed up.
One more challenge conquered!
Thanks for all the suggestions!
Jo
