Hi everyone..
Im having a problem with Robohelp 8 rigth now. When i import a Word document everything work fine. and you can se everything al the content on the Robohelo editor just like you have it on your word document But when you check the preview of the topic you dont have any knid of stile on the fonts..
The same happend when you generate the layout.
you can see the title in the editor...
but you can't see the style on the preview
is pretty weir because i think that the styles are getting importe fine (you can see them on the RH editor) but somthing happen later.
Any ideas?
thanks, Sabin
It doesn't work, because your style starts with a number. Rename the style, so it starts with a letter. You may use numbers in a classname, just don't start with them.
Greet,
Willam
PS. One tip: You may want to change the <span style> to a <span class>. It's easier to applay and much easier to maintain.
Can you post the html code and css markup of the paragraph?
Greets,
Willam
html
css
Greet,
Willam
Thanks a lot W. van Weelden!
