Cannot open or place .png files in Illustrator
Guest
Aug 17, 2009 Aug 17, 2009
I recently created a logo in Illustrator CS3 using a .png graphic generated by Flash CS3, and while it was working fine last week, today when I tried to modify the logo, it suddenly closed, and whenever I try to open or place a .png file, it does nothing, and whenever I try to open a file with a placed .png graphic from Flash, it automatically closes the file. Do I need to re-install the program? And if so, I'm on a Mac, how do I do that? Thanks for any advice anyone can offer...
28.8K
Adobe
Try this…
I would first quite Illustrator and then;
I would go to Users/username/Library/preferences/Adobe Illustrator CS4 Settings folder and trash that settings folder.
I would also trash the com.adobe.illustrator.plist also in the users preferences
Guest
Hey Wade, thanks--I tried both those things and emptied the trash,
and this time I saw the file for a brief second before it closed it.
There was also an "Adobe Illustrator CS3 Library Settings" folder in
that Users/paulab/Library--should I try trashing that as well? Thanks
so much,
Paula
Yes why no try that again and the library settings as well then repair
your permissions using the Disk Utility application in the
Applications / Utilities folder.
then restart your computer.
If this does not work then create a new user account and log into that
and let us know if the clears the problem.
Guest
Aug 18, 2009 Aug 18, 2009
Hi Wade,
hmmm, still didn't work--I trashed both library settings and settings
in that folder for Illustrator, plus the plist, emptied the trash,
repaired disk permissions (which I've done a couple times in the past
few days already, hoping it would clear up this issue) and re-booted.
Are there any other ideas? I could boot from my computer's system CD
installer disk and run disk utilities to repair, but when I go to
"verify" from this harddrive, it tells me nothing is wrong. My other
thought was to run an older Norton disk and run Speeddisk, but am not
sure how doing this from a OS9 disk will work with a OS10.4.11
computer...
I guess last ditch would be to reinstall Illustrator. If it helps, I
should probably point out that I also have CS1 on this machine, but
rarely use it, except occasionally InDesign, to test a file, and am
wondering whether I should take off Illustrator and Photoshop from
that suite.
thanks,
Paula
Did you try making a new user account and see if it works there? System Preferences>System>Accounts
Guest
Yes, I created a user acct named "test" and tried it from there--the
file linked to it. I also tried opening the other .png files in that
folder that I'd created from Flash (export > as image > .png),
whereas the jpg I created of the same image opened just fine. Could
it be a Flash problem in creation of the .png files?
Are you able to open the .png files in Photoshop? Have you tried resaving them there and then opening in AI?
Guest
Yes, I can do that! Cool! The only trouble is that one side of the
graphic (it is a globe with the Americas) is covered by a mask, but a
Photoshop .png file had no trouble.
Oh, yes I think so can you export it to Illustrator and make the png
from there.
I believe this is a bug.
Wade.. you might want to fix the typos in your boilerplate copy/paste solution.
Aug 19, 2010 Aug 19, 2010
I have an odd problem similar to this post. Some transparent PNGs that I create in Photoshop will not place or open in Illustrator. However, others do! They are product photographs I'm trying to place. The ones from our old photographer work fine (after I cut out the background...hence the reason for the PNG.) However, the images from the new photographer, when the background is cut out and made a PNG will not place.
I don't believe this has always been the case though. I've had this issue for a while and wiped my computer (mac) and reinstalled CS3 and still have the issue. So odd. Any thoughts? I even tried changing color profiles and see any other differences in the pngs and original JPGs.
Any help is very appreciated.
Okay. I think maybe I solved it? I resized the image to make it a bit smaller and it placed fine. Coincidence? Would this be an issue? I took it from 12" wide to 8" wide. Thanks.
